Summary: How to use a Glue Gun effectively and safely as an inexpensive and simple method of bonding materials
A glue gun is a gun that uses a heating element within to melt a solid glue stick (Hot melt adhesive) to deliver amounts of glue to immediate positions.
Glue guns come in two different formats, High temperature (hot melt version) and Low temperature. Dual option guns are available. Low temp glue guns are more suitable for more delicate items such cloth / materials.
Glue sticks are manufactured in many sizes (different glue stick diameters) for all types of glue guns.The most common used is 11mm. You can also get dual purpose glue sticks that work hot and lower temperatures. For domestic use there are only a few types of glue sticks available. As you venture into the commercial market the options increase.
Before using your Glue Gun you should always follow set procedures to get the best from your Glue gun.
Remember you are using a heated device so when cleaning or possibly touching the hot glue wear protective hand gloves. Glue is painful to remove from your skin!
At DIY Doctor wel always say you usually get what you pay for so we recommend that you consider what you want this tool to achieve and spend the appropriate amount of money on your Glue Gun. Options are available from our tool store to the right of the page.
