WELCOME TO OUR Using a Rasp PROJECT
Summary: How to use a rasp to remove and shape timber safely.
A rasp is usually a woodworking file. Unlike a metal file, where the teeth are set very close together, a rasp has teeth set quite wide apart as well as being deeper. This leads to a much coarser cut and allows for quite a lot of surface material to be removed in one stroke.
A rasp blade is coarse and designed to remove a lot of material in one passRasps are also used to remove surfaces of other materials such as horses hooves and they are often used to shape soft stone when carving or sculpting.
Rasps are designed to shape a surface quickly and can be bought with a variety of tooth settings so the finish can get smoother as the work goes on. Much the same as using a heavy grit sandpaper before moving up to a finer grit for finishing.
Rasps, as with metal files, are designed to cut or plane on the stroke away from the body. Using a rasp or file inRasp sets come in different types for forming shapes both directions will eventually ruin the teeth. Rasps, again, as with files, can be bought in a few shapes.
Rasps can be flat on both sides, flat on one side and half-round on the other, completely round or triangular. These shapes allow for most types of shaping to be done with a rasp before the work is finished using finer tools.
See also our project on using files.
Forums
Hand & Power Tools
Post new topic
No new posts Any suggestion to make my DIY woodworking tools sharp again?
3 Martin Ro 69
stoneyboy View latest post
No new posts looking for specific tools
2 whity 811
Martin Ro View latest post
No new posts 14.4v Charger
2 jasisdad 227
No new posts Skirting board in-situ cutter
1 Alvin Wyl 84
No new posts Whats your best / most useful tool?
0 reggae88 131
reggae88 View latest post
No new posts Router guide bush
0 brimar 141
brimar View latest post
No new posts bandsaws..
0 sweetorb 279
sweetorb View latest post
No new posts Looking for a really excellent toolbox...
2 simonlove 1003
Skids View latest post
No new posts Heat gun research - Industrial Design
0 ale_slash 381
ale_slash View latest post
No new posts Bench Grinders
0 Jed 530
Jed View latest post
No new posts Yankee screwdriver bits.
2 wrinklyto 1252
rosebery View latest post
No new posts Small Angle Grinder
1 EdThomas 779
No new posts cutting laminate cabinet doors with a circular saw
1 rrmaison 891
No new posts PIPE BENDER
3 greengras 1062
greengras View latest post
No new posts Drill a 10cm dia hole in reinforced concrete
3 torsheeda 1091
TheDoctor View latest post
Display topics from previous:
Post new topic     -> Hand & Power Tools
Jump to:
Loading...
© Copyright Diydoctor Ltd 2010  Developed by Boson Media  Hosted by Rackspace
