Summary: Choosing a water butt, installing a water butt, conserving rainwater for the garden.
With water metres and hosepipe bans restricting water usage in the garden, installing one or more water butts to save rainwater is the best way to create a ready supply of free water for your plants. They will thank you for it, as rainwater is much better for plants than tap water. A water butt can be fitted to any downpipe where there is space to sit a container either directly underneath or nearby.
A wide range of sizes and styles are available, allowing you to choose a suitable water butt for every location. If you don’t have much space, slimline models are available. If it’s price you’re concerned with, standard green plastic barrel type water butts are very reasonable and often come with a matching stand and tap. If you
have a traditional cottage garden and don’t want a big plastic barrel to spoil the look, then you can buy genuine oak whisky barrels. Plastic butts in the style of terracotta pots, stone containers and wooden barrels are also available. If you have a large roof and need to store a lot of water, you can connect two or more butts up together or invest in a really large storage tank.
Make sure you purchase or make a stand for your chosen butt so that you can fit a watering can under the tap. A large barrel full of water is very heavy so make sure your stand is either purpose-made or very sturdy. Bricks or concrete blocks can be used to good effect. Not all water butts are sold with taps, so make sure you purchase a suitable one if needed.
All water butts should be sold with a lid, both for safety and to keep the water fresh by stopping leaves and other debris from falling in. If you have young children, look out for water butts that feature a child-safe lid.
You can either cut off the downpipe and place the water butt directly below it, with the cut-off pipe going through a hole in the lid, or you can install a rainwater diverter. This is often a better option as it means that an overflow pipe is not required, and it gives more flexibility for siting the butt.
Whether you have round or square downpipes, you should be able to find a diverter to fit. Place your butt on its stand next to the downpipe, and mark the height of the butt on the pipe. Use a hacksaw to cut the downpipe 3cm down from your mark.
Attach the rainwater diverter to the downpipe where you have cut it off. Attach the piece of pipe you cut off to the bottom of the diverter.
Drill a hole in the side of the water butt, 8cm down from the top. The hole needs to be just the right size to fit the connector fitting of the diverter through. Fit the connector piece in place by pushing it through the hole you just drilled and screwing the supplied washer and nut on.
Attach the diverter to the water butt with the piece of pipe supplied. Fit the lid onto the water butt and wait for it to rain!
The level of the diverter should be such that when the water butt is full, it won’t overflow – instead the rainwater will just go down the drainpipe. If you find your water butt is overflowing, firstly check that the diverter pipe is not blocked with leaves or moss. If it is not blocked, it could be that the diverter level is too high on the downpipe. Try wedging something underneath the water butt (empty it before you attempt to move it) to raise the height.
Water butt connecting kits are available if you want to install more than one water butt to a downpipe.
