DIY Doctor
Building Regulations for Wall Cavities With Existing Extension and Proposed new Extension
Postby Aliyat » Thu Nov 23, 2017 12:29 pm
Hello,
We live in a midterrace house with the half-width extension consisting of kitchen and bathroom at the rear. We are looking to extend and make extensions full width, which means it will be between rear extensions of two neighbours. As initial extension was built in 60s or 50s wall when the requirement was 250mm wall cavity, whilst it is now 300mm due to higher insulation requirements. Whilst we are happy to have 300mm cavity on a new wall, we are a bit confused with existing wall. As our architect advised it is easier and cheaper to demolish whole extension and build it from scratch because "Builders can charge more for fiddling around (because it is labour intensive) than for starting again.  Concrete blocks are only 50p each and it wouldn't take them a day to replace the wall.", which we also understand but behind our existing wall is the neighbours wall. It seems such unsustainable move to remove existing wall to comply with current regulations whilst there is neighbours wall right behind. Is there a regulation for cases like ours? We were also thinking to leave existing wall as it is by having full width extension for half length only? Please advise. Thank you.
Aliyat
Rank: Labourer
Progress to next rank:
25%
Postby michaelscad » Sun Nov 26, 2017 3:23 pm
if you are rebuildng an existing it won't need, planning permission they will need building regs
but it's worth thinking about maximising the rebuild
may be into a full height extension and
extending out as far as you can .i've done drawings for complete terraced sebuild
with full rear extension and loft coversion
they are in pdf format so i can't post them on this forum i'd be happy to email them
michaelscad
Rank: Tradesman
96.2%
Postby Aliyat » Mon Nov 27, 2017 10:16 am
michaelscad wrote:if you are rebuildng an existing it won't need, planning permission they will need building regs
Thank you, Michael. Couldn't find how to PM.
Aliyat
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
