I have a thermostatic bath / shower mixer tap running off a combi boiler, I have had It few years now, the temperature is set to 38 It runs fine nice steady temperature for having a shower, but I can't make It run colder, I can get It hotter but not colder, I can press the red button down and turn temperature control anti clock wise to make It hotter, but when try to turn It clock wise It will only move a little, It won't turn all the way to make colder.
Sounds very much to me as though the hot and cold pipes on the thermostatic valve are fitted the wrong way around. It's normally anti-clockwise for cooler and the red button is a safety button so you cannot accidentally turn the temperature above 38 degrees, it's certainly not to make the water cooler.
DIY how to tutorial projects and guides - Did you know we have a DIY Projects section? Well, if no, then we certainly do! Within this area of our site have literally hundreds of how-to guides and tutorials that cover a huge range of home improvement tasks. Each page also comes with pictures and a video to make completing those jobs even easier!
