I've just moved into a new build flat, and am looking at getting a water softener installed. I don't have enough space under my sink, but I'm not that fussed about having a drinking water tap, so I was looking at maybe putting it in the utility cupboard.
However, my understanding with water softeners is that *usually* they are connected at the mains, and then the softened water is passed to the boiler, etc. However, in my utility cupboard, I can see the cold mains feed - but am confused as there seems to be a separate hot feed.
Photos are below - could someone more knowledgeable/experienced than me clarify? The pipes that go off to the right look like they go into the under floor heating.
I do believe there maybe some sort of communal water heater, which would explain it. But does this mean I can't have a water softener? Or if I do, it will only soften the cold water
So bit of an update - I now understand I have a heat interface unit (HIU). But does this mean the hot water comes in in separate pipe to my mains cold? Or does the HIU simply warm up my cold mains water?
Figured it out. Found it from the product page for my HIU. "The instantaneous hot water heaters inside each heat interface unit shall heat incoming mains cold water via a plate heat exchanger using heated water from the community heating system."
DIY how to tutorial projects and guides - Did you know we have a DIY Projects section? Well, if no, then we certainly do! Within this area of our site have literally hundreds of how-to guides and tutorials that cover a huge range of home improvement tasks. Each page also comes with pictures and a video to make completing those jobs even easier!
