Post
by notveryhandy »
Fri Feb 26, 2010 8:45 am
[quote="stoneyboy"]notveryhandy,
"Am I in order, please, to introduce the Inhibitor via the header tank" [u]NO[/u]
Buy some inhibitor in a tube which will fit in a mastic gun and dose the system through the vent on a radiator.
end[/quote]
Thank you. Were it that easy :( All the rads in the house are not, what I call, of conventional design, in that the only available orifice is the bleed valve itself. There are no blanking plugs or boss incorporating the bleed valve screw. Per chance I managed, yesterday, to track down the current manufacturers of this type of combination cylinder and had a very helpful chat to a guy in their technical dept. I now understand the workings of this type of combination cylinder and can confirm that the correct, and probably only way, to add inhibitor is to shut the cold water inlet to the integral header tank, drain off sufficient water from a downstairs radiator, introduce the inhibitor then allow the system to top up. Easy I know, but I had not come across this type of cylinder or system before and I wanted to make sure. (The system also has two separate pumps).
I have posted the result of my findings should any other person be faced with the same situation.
However thank you once again for your response.
