Post
by Allathan »
Mon Aug 24, 2009 1:48 pm
[quote="stoneyboy"]Allathan,
Not sure what you are trying to achieve with the thermostats but I would recommend you fit one recommended by Hunter.
end[/quote]
Stoneyboy,
Many thanks, have tried Hunter and they would not commit to anything.
The high and low stats are to keep the gravity loop (tank and heat loss rad) at between 45 and 90 degrees before allowing pump to come on. Also roomstat and timer to power pump as well. Pump is running 4 rads on its' loop.
I have been advised to get Honeywell gear as follows:
High and Low limit pipestats
st9100c timer
dt200 roomstat.
The guy in the plumbers merchant said this was what i would need but hes not an installer of any kind and the dt200 is 2 wire when the system needs a 3 wire stat (unless theres a weird way of doing it)?
