boiler off pump running
Postby exdsjy » Thu May 15, 2008 8:26 am
came home to find pump running although system had closed down(ON TIMER) 2 hrs. earlier. next day HW would not work but selecting Heating made boiler fire.
exdsjy
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Thu May 15, 2008 3:22 pm
Type of boiler, system and controls ?
Does turning the room thermostat down stop the pump ?
It seems like the actuator is at fault, this should switch across for water or heating, it sounds like it's stuck in heating position change actuator head
Abit more info will help.
Rank: Project Manager
Postby exdsjy » Fri May 16, 2008 9:12 am
[quote="htg engineer"]Type of boiler, system and controls ?
turned out it was motorised valve. Thanks.
exdsjy
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
