boiler
Postby bazza » Tue Feb 16, 2010 5:49 pm
hi everyone.halstead combi boiler, hot water comes on for a couple of minuetes then cuts out. if i leave the boiler on standby for a few minuets n create a demand for hot water it will come back on hot for a couple of minuets then same again anyone any ideas cheers bazza
bazza
Rank: Ganger
Progress to next rank:
79.3%
Sponsor
Simply Build It
Postby thegasman » Sat Feb 27, 2010 9:33 pm
could be a couple of things, firstly you need to remove the cover and see if it runs properly-ONLY do this if Qualified to do so- if it runs ok then it is likely that the fan venturis are dirty and need cleaning out, if it still doesnt run properly we need to establish whether or not the hot water demand is constant or not if it is then its either a plate heat exchanger or thermistor problem if the demand is dropping out it could just be a diaphragm or microswitch-more info needed really to be sure
thegasman
Rank: Apprentice
31.6%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
