Can't Remove the Plastic Radiator Valve and the it is Leaking!
Postby denbob30 » Thu Jun 05, 2014 4:30 pm
Help
My radiator valve is leaking from under the plastic cover. I can't seem to remove the cover to do any repairs that I have read to try. What can I do?
denbob30
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby proptech » Sat Jun 07, 2014 10:19 am
Hi denbob30
If there's no screw in the top, then the cover will simply pull off. As far as the leak is concerned, try tightening the nut at the top of the valve. This usually solves the problem, otherwise it's a replacement valve.
proptech
Rank: Foreman
71.7%
Postby denbob30 » Sat Jun 07, 2014 11:27 am
That's what I thought and that is the case with other radiators in the house but not this one. It is completely stuck for some reason! I intend to try tightening the nut... When I can get to it.
denbob30
Rank: Labourer
50%
Postby proptech » Sun Jun 08, 2014 6:10 pm
So if the others pull off, sounds like a bit more wellie is required. Let's face it, if you break the plastic, it's not the end of the world. The leak is the important point.
proptech
Rank: Foreman
71.7%
Postby denbob30 » Sun Jun 08, 2014 7:37 pm
I don't mind breaking it... I just can't. What do you suggest I use?
denbob30
Rank: Labourer
50%
Postby proptech » Mon Jun 09, 2014 5:44 pm
Difficult to say, as I've no idea what's in your tool kit. personally, I'd give the thing a good squeeze with a pair of water pump pliers.
proptech
Rank: Foreman
71.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
cron
