Price Doctor - Extension quote and price checking software
Save up to 50 percent off subcriptions to some of the best DIY and Home Improvement magazines
DIYDoctor
DIYDoctor
Home   Contact   DIY How-to Projects
  • Forum Index
  • FAQ
  • Search
  • Login
  • Register
  • Board index ‹ DIY and Home Improvement Forums ‹ Lofts & Loft Conversions
  • FOLLOW US
    Twitter Logo Facebook Logo YouTube Logo
    • HOME
    • DIY PROJECTS
    • DIY TIPS AND TRICKS
    • REVIEWS
    • GARDENING
    • DIY VIDEOS
    • GREEN LIVING
    • HIPS
    • FIND TRADESMEN
    • PRICE DOCTOR
    • FORUM
    • BLOG
    • NEWS LETTER SIGNUP
    • SHOP
    • SUPPLIERS
    • ADVERTISE HERE
    • PRESS
    Recommend This Page
    Tweet
    Trustmark and the NHIC
    DIY Doctor are
    members of:
    National Home Improvement Council
    Trustmark - Government Endorsed Standards
    Ceiling material for loft storage/playroom
    Post a reply
    2 posts • Page 1 of 1
    Postby Trevor McAlister » Fri Dec 31, 2010 5:51 pm
    I am in the process of insulating & boarding the loft, after raising the floor height to get in 250mm of Rockwool insulation, and put in a new 1.5m x .075m loft hatch.
    I was just considering the materials (and the cost) that would be best to use if I was to put some kind of ceiling on the underside of the roof rafters, along with jablite insulation between the rafters. It’s not a proper habitable room so plaster board is not necessary, and it will be 3-5 years before its used as a proper playroom as the little one in under 3 at the moment.
    My dad has suggested using plywood, but this would not be cheap for a loft with a floor area of 3.5m x 11m, at £25 for each 4’ x 8’ x 18mm sheet, I suspect 5mm sheets would be in the £6.50 region if I can find them.
    I was just looking at 4’ x 8’ x 3mm Hardboard which is only £5.28, the cheapest option so far. I wasn’t shore whether to put the smooth side facing up or down though, down would give a better finish to the loft ceiling and it wouldn’t require painting.
    Trevor
    Trevor McAlister
    Top
    Postby happyhacker » Fri Feb 18, 2011 6:36 am
    IHO you will eventually be using the room as a habitable room so must meet the building regs. If this is the case the joists must be strong enough to take habitable loads. Then you would not insulate the floor but the space between the roof rafters! You should also build proper stairs as loft access ladders will not be suitable for todlers.
    I am in the same position as I want to use the roof as a store room but maybe later a habitable room so I am going to insulate the rafters, put on plasterboard. For insulation see Google "jablite.co.uk" or go to B&Q and start asking. At the end of the day you should draw up some plans and if you get that done and approved you have 5 years to start.
    You would need proper floorboards I would use 19mm ply but consider access for wiring underneath and no insulation. I am going to put in some rooflights. A biggish project but do it properly and you will have added value. All the best!
    happyhacker
    Top
    Post a reply
    Return to Lofts & Loft Conversions
    • { RELATED_TOPICS }
      Replies
      Views
      Last post
    • Cracks in ceiling after loft conversion.
      by iamjames » Sun May 22, 2011 7:07 pm
      Last post by iamjames View the latest post
    • ?? How to hold open a loft hatchthat opens up into loft??
      by reeh2 » Tue Jul 27, 2010 6:02 pm
      Last post by stoneyboy View the latest post
      Wed Jul 28, 2010 10:54 pm
    • loft con
      by woblow » Tue Jan 19, 2010 9:55 pm
      Last post by woblow49 View the latest post
      Wed Jan 20, 2010 9:58 pm
    • Converting the loft
      by Rastanking » Sun Jun 21, 2009 2:41 pm
      Last post by Rastanking View the latest post
      Tue Jun 23, 2009 11:57 am
    • Weights in the loft
      by pc6844 » Tue Sep 08, 2009 2:25 am
      Last post by Dan the man View the latest post
      Wed Sep 16, 2009 3:15 pm
    • Board index
    • The team • Delete all board cookies • All times are UTC
    • SitemapIndex SitemapIndex
    • RSS Feed RSS Feed
    • Channel list Channel list
    Powered by phpBB® Forum Software © phpBB Group
    Diy Doctor Ltd  (Company No. 5863375)
    DIY  |  DIY How To  |  DIY Forum  |  Terms & Conditions  |  Privacy Policy  |  Cookie Info
    © Copyright DIY Doctor Ltd 2011  Developed by Boson Media  Hosted by Rackspace
