Cental heating comes on when timer is off!
Postby Ian Graham » Mon Jan 19, 2009 5:44 pm
Have central heating system controlled by Lifestyle LP522.
Heating will come on although contol shows heating is off.
Any ideas?
Ian Graham
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby Steve the gas » Tue Jan 20, 2009 5:56 am
Hi Ian,
Does it happen at night mainly?
Could be you have a frost stat on your boiler which will overide all controls when temp goes too low near boiler, this is to prevent pipes freezing/bursting.
Hth
Steve the gas
Rank: Site Agent
56%
Postby Ian Graham » Tue Jan 20, 2009 6:25 pm
Hi Steve,
have found a thermostat in garage where boiler is situated.
Have turned it down to the lowest which is 3 degrees. (was at 6 degrees)
Will let you know if that doesn't work.
Many thanks
Ian
Ian Graham
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
