Chaffoteaux Calydra 80 boiler won't light
Postby JOEBOUK » Mon Dec 29, 2008 3:14 pm
My boilers cut out today and won't relight. The pilots out and can't see a manual way of relighting it.
So am I right to believe the PCB automatically controls it when theres power to the boiler. Anything else I could try before replacing the PCB?
Basically its dead, when I turn it off and back on again it clicks and justs stands dorment. I've tryed the reset button aswell to no avail. The fan kicks in when hot water is requested, but still no pilot so no burner.
Any advice would be much appreciated, cheers
JOEBOUK
Rank: Labourer
Progress to next rank:
25%
Sponsor
Simply Build It
Postby htg engineer » Mon Dec 29, 2008 8:15 pm
Is it definately electronic ignition ?
If there's normally a permanent pilot - and now there isn't - there's the fault.
htg
Rank: Project Manager
Postby JOEBOUK » Tue Dec 30, 2008 9:51 am
Pulled the cover off since and from what I can gather the gas travels through 2 solenoids to the burner at which point the PCB operates a high speed spark to ignite it. The manual states theres an 8 second delay, after that if no heat is detected the gas is closed off. There is no permanent pilot.
So I should be getting 8 seconds worth of gas? I'm getting none at all, am I looking at new solenoids or new PCB, something else I'm missing perhaps??
Manual (pg13) Google "theinitiativegroup.org"
JOEBOUK
Rank: Labourer
25%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
