Daft radiator question
Postby stoner » Fri Oct 31, 2008 10:37 am
Okay, sorry if this seems to be a really stupid question but I'm going to remove a radaitor for decorating (which I haven't a problem with). The thing I've been pondering is how does the system top itself up to replace the water lost from the removed radiator. This has made me think after reading the manual to my Boiler where it mentions being a sealed system and cannot find no mention on what to do if any part of the system is interupted. I have an Alpha CB28 combi-boiler by the way, no tanks in the loft or anything, everything's direct from the mains.
stoner
Rank: Labourer
Progress to next rank:
50%
Sponsor
Simply Build It
Postby AdamsHeating » Fri Oct 31, 2008 12:57 pm
Not a daft question, just one you don't know the answer to.
Sealed systems will usually have a filling point called a filling loop. You use this to top up, whilst bleeding the radiator of air. The system pressure usually need to be at 1bar when cold, this is indicated on the boiler pressure gauge usually.
Hope this helps,
AH
AdamsHeating
Rank: Ganger
47.3%
Postby nitro23456 » Fri Oct 31, 2008 1:15 pm
use the fill loop to top up the pressure just above 1 bar
nitro23456
Rank: Foreman
48.7%
Postby htg engineer » Fri Oct 31, 2008 2:18 pm
It doesn't refill itself, you have to re-pressurise via the combi fill loop.
htg
Rank: Project Manager
Postby stoner » Fri Oct 31, 2008 3:33 pm
thanks for your reply, I had a funny feeling that this was the answer
stoner
Rank: Labourer
50%
Postby stoner » Tue Nov 04, 2008 6:57 pm
Another question if anyone could offer advise. Found the fill loop easily so no problems there. Just wondering what the sequence of events are once the radiator is reconnected. Do I?:
1. Leave boiler off?
2. Reopen both radiator valves?
3. Bleed radiator whilst repressurising system or repressurise then bleed.
Sorry if this seems a simple question to some but I've never had experience of sealed CH systems in any of my previous houses, they've always refilled themselves from loft tanks.
Thanks again
stoner
Rank: Labourer
50%
Postby AdamsHeating » Wed Nov 05, 2008 4:30 pm
exactly as described.
refit rad, open valves, pressurise the system to 1.5-2 bar and close off the filling loop, then bleed rad. keep doing until radiator is full and system pressure is at 1bar or whatever your MI (manufacturers instructions) state.
AdamsHeating
Rank: Ganger
47.3%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
