filling up heating system
Postby mikeharrison » Thu Jul 19, 2007 7:03 pm
hi
i've drained my central heating system to replace some rads and when i've filled the tank up in the loft no water is getting into the system. i've opened every bleed valve on the rads and also the two drain points i have on the system and i still can't get water into the system. what i'm i doing wrong
thanks
mike
mikeharrison
Rank: Apprentice
Progress to next rank:
5.3%
Sponsor
Simply Build It
Postby GeckoGas » Tue Jul 31, 2007 6:19 am
How old is the system? Sounds like a blocked cold feed to me.
GeckoGas
Rank: Tradesman
3.8%
Postby mikeharrison » Tue Jul 31, 2007 7:32 pm
hi
it's about 12yrs old where would the cold feed be blocked and how could i unblock it
thanks
mikeharrison
Rank: Apprentice
5.3%
Postby GeckoGas » Thu Aug 02, 2007 7:26 am
Hi; this will depend on your system type... The cold feed can be found by tracing the outlet of the feed & expansion tank down to where it enters the system - This point is called the "neutral" point or more commonly known as the cold feed although technically this is the entire length of pipe.
The easiest way to check is with a strong magnet - Simply touch the magnet to the copper pipework; if it sticks and provides quite a bit of resistance; the pipe is blocked and will need cutting out and replacing.
GeckoGas
Rank: Tradesman
3.8%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
