Post
by plumbbob »
Tue May 25, 2010 9:32 am
In theory this could be done and the distance is not really an issue. The tricky bit is deciding where the supply should run and a careful calculation is needed to determine the required pipe diameter.
Of course, this isn't something you can do yourself as all gas installations need to be completed by a registered installer. IF you contact a couple of local gas installers you will get definite answers to both your questions.
