Flueless gas fire.
arlette marsh
Flueless gas fire.
by arlette marsh » Thu Nov 26, 2009 7:02 pm
I have a flueless fire,fitted by Qualified Gas Fitter.I have a wooden fire surround and want to Know if there is something I can use to stop the varnish from blistering.The fire is not in constant use and only used to take the chill off the room on a very low setting. :P
by htg engineer » Fri Nov 27, 2009 8:50 am
Heat resistant paint should be used - if it's blistering then it's a fire hazard. Check instructions for the fire it'll give minimum distances.
htg
