gas pipe
Postby musky71 » Sat Aug 25, 2007 12:15 pm
my builders have concreted the footings for my new extension,over the gas pipe,is this correct?
musky71
Rank: Labourer
Progress to next rank:
0%
Sponsor
DIY asbestos test kits
Postby LES COWIE » Wed Sep 05, 2007 8:02 pm
The gas pipe should be laid in sand and there must be a lintel over the pipe as it runs under the foundations. Best idea is to alter the incoming pipe so it enters the wall above ground level. Remember all gas work must be carried out by qualified gas engineers
LES COWIE
Rank: Apprentice
47.4%
Postby rosebery » Sat Sep 29, 2007 12:42 am
The gas pipe should be laid in .............
It might be after all all he can see is the concrete.
best idea is to ..........................
discuss your concern direct with the builder and assure yourself it was done correctly and according to bldg regs. If it wasn't get him to do it again at his expense.
Did you need planning permission for this work? If so, no doubt at some stage (well several really) there will be a bldg inspector along to have a peek and ensure it is being done properly.
rosebery
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
