Halstead Ace High
Postby Phil C » Wed Feb 16, 2011 10:22 pm
Why does my hot water go cold when running the hot tap??
It will run hot when first turned on then sometimes goes cold!!
It takes 2 - 3 times of turning hot tap on/off before I can get the hot water to stay on!!
Can someone tell why this is!!
I have recently had it serviced and the plumber said it was fixed!!
Phil C
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby Cheesie1 » Sun Feb 20, 2011 3:44 pm
With a combi normal to get cold water first (water in pipes from boiler to taps), then hot (water been sat inside boiler heat exchanger), cold again then hot as pressure switch brings boiler on! Water should then stay hot! If not try closing tap down slightly this should then remain hot constantly! If ur used to a system boiler (hot water tank) it can seem strange but normal.
Cheesie1
Rank: Tradesman
34.6%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
