Honeywell Mechanical Thermostat Replacement With new Honeywell D90E
Postby andreaaermones » Fri Feb 03, 2017 8:31 am
Morning all,
I m looking to replace an old Honeywell mechanical thermostat with the new Honeywell D90E.
I am a bit confused about the wiring in the old thermostat. I have 4 cables, brown, grey, black and yellow stripped. I am not sure which ones of these though need to be connected to the new thermostat.
Could.you please help?
Thank you all for your time :)
andreaaermones
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby GayEddie » Fri Feb 03, 2017 8:36 pm
Hello
Not sure which honeywell stat you have but if it is a T6360 there will have numbers there on old stat.
the green and yellow wire is the earth wire
#2 is the neutral wire
then the other wires will be in #1 and #3 on the old stat one of the wires will be from your clock heating on, the other goes to motorized valve and fires boiler.
Now your new stat has connectors A and B you will have to put the neutral in a block connector to make safe, not sure if you have multi meter but what you want is the wire from the clock ( either 1 or 3 on old stat ) wants to be in A and the one to boiler goes in B
Hope this helps
GayEddie
Rank: Apprentice
73.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
