by ericmark »
Sun Feb 10, 2008 5:03 pm
Will guess motorised valve micro switches. Try moving bleeding leaver on valve to bleed position if it then works most likely valve. The leave will normally latch and when full over the valve is in centre position so both central heating and hot water will work together. I am assuming you are wired to Y plan if not then sorry this does not apply.
