Hot Water no central heating
Postby robharpin » Wed Dec 23, 2009 6:14 pm
hi i have a baxi 522 back boiler with a honeywell st699 prg a room thermostat and a cylinder with a three way valve , when i switch the prg to constant central heating the three way valve moves across but no power to pump , when i turn hot water on constant no problem the pump kicks in i have tested the power from the room stat and it seems ok in the wiring center , was wondering if the problm was in the three way valve as tho everything says open valve the room stat and prg but as tho one of the wires coming out of it to the pump is saying get lost , any help would be appriciated thanks
robharpin
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby rosebery » Sun Dec 27, 2009 11:20 pm
Could you translate this bit please?
"as tho everything says open valve the room stat and prg but as tho one of the wires coming out of it to the pump is saying get lost"
rosebery
Rank: Project Manager
Postby griffo » Mon Dec 28, 2009 10:44 pm
Reading between the lines you need a three port valve or at least the head if its motoring but not switching.
griffo
Rank: Apprentice
73.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
