Post
by XDB »
Sat Apr 18, 2009 4:55 pm
I will inform the forum of the latest position, I found an installers manual on the web, error code 7 is a flue temperature sensor but it may be caused by air in system. I started at the pump i removed the centre plug and bled it. The system then fired up, but there was a lot of air in the system I had to bleed nearly every radiator. I don't know where the air is coming from. When I reduced the room temperature I was back to square one, no hot water at the taps.
The lack of any helpful advice, in fact any advice at all, means I will have to try and sort the problem myself. I think the inventor of the combi boiler deserves a quick kick in the nuts.
