NO HOT WATER
Postby BOBAKQ » Sat Mar 22, 2008 8:49 am
WE HAVE BAXI COMBI BOILER, THE HEATING IS OK BUT THERE IS NO HOT WATER AT ALL,PLEASE HELP[/b]
BOBAKQ
Rank: Labourer
Progress to next rank:
75%
Sponsor
Simply Build It
Postby htg engineer » Sat Mar 22, 2008 11:22 am
probably needs a replacement diaphragm in the pressure differential valve.
This located at the bottom left of the boiler - just behing the CH/HW selector switch, drop the front panel and when the hot tap is opened the pin should come out and operate the microswitch - if the pin doesn't come out change the diaphragm.
Rank: Project Manager
Postby BOBAKQ » Sat Mar 22, 2008 9:39 pm
Do I need to turn water off or is there any water in the system I need to drain, before attempting this.
Bob
BOBAKQ
Rank: Labourer
75%
Postby BOBAKQ » Sun Mar 23, 2008 1:55 am
HI M8 IT IS ME AGAIN, AFTER MY LAST POST THE NEON FOR THE FAN STARTED FLASHING AND NOTHING WORKS.
BOBAKQ
Rank: Labourer
75%
Postby htg engineer » Sun Mar 23, 2008 8:41 am
You need to isolate the cold water, and drop the pressure from the boiler.
Check first - with the hot water tap on - does the pin come out ???
Have you tried resetting the boiler after the fan light came on ? turn to reset and hold for 5 seconds then let go.
If it's a Baxi HE - it'll probably be a air pressure switch at fault - not the fan
Postby BOBAKQ » Sun Mar 23, 2008 5:11 pm
it is a baxi combi 105e
BOBAKQ
Rank: Labourer
75%
Postby htg engineer » Mon Mar 24, 2008 10:22 am
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
