Post
by Clar »
Sat Nov 08, 2008 6:10 pm
[quote="Clar"][quote="Steve the gas"]Hi Clar,
Is the right hand valve a TRV?
If so its prolly the pin sticking down-- take head off and pull pin gently up about 3 mm, spray a little wd40 on it also
Hth[/quote]
Thanks Steve, Yes it is a TRV. I will have a look at how I can remove it and see if there is a pin in there. The TRVs a pretty old. We have been living here for the past 20 years and they were on the rads then. There are settings from 1 to 5.
Having had a look they are not all the same on all the rads. Will look in daughter's room once I get her out of the room. Will get back to you once I can gain access.[/quote]
Thanks a million :D :D :D The radiator is now really hot, .... will have to turn it down a bit I guess. I am really pleased with your advice, you have saved me money not having to get an engineer in and for that I am really grateful. Thanks again Steve. :wink:
