rads hot at top
Penrhyn
rads hot at top
by Penrhyn » Sun Jan 04, 2009 12:36 pm
Some of our radiators are hot at the top and much colder at the bottom. The ones on the upstairs seem to be OK, it's just the ground floor.
I've checked the header tank and bled radiators. I can't bleed the whole system as we have an air diverter (correct name?). The pump has recently started to make a ticking noise but does seem to be working OK.
We have a conventional Potterton boiler system with a bypass as we have TVRs on all radiators.
Any advice appreciated as it's cold here!
TIA
Penrhyn
Steve the gas
by Steve the gas » Mon Jan 05, 2009 5:22 am
Rads cold at the bottom indicates sludge in the system.
This will make your pump struggle.
Solution (depending on your skill set) is drain & flush a few times, add cleaner for the required period, drain again > add inhibitor.
Failing this get a good recommended firm to powerflush it (£300 +)
but not BG.
