Room stat is one needed with TRVs
paulanliz
Post by paulanliz » Thu Dec 18, 2008 9:29 pm
Hi am having a completely new heating system fitted and we are having TRV on all radiators the boiler will be a worcester bosch 27cdi so is it necasery to put in a room stat because with the old system we just turned it to full and let the TRVs do the work
plumbbob
Post by plumbbob » Fri Dec 19, 2008 2:30 pm
TRV's cannot be used to control the heating entirely as they only approximately control the flow of water through the radiator. A room stat is a necessity to ensure the boiler doesn't continue heating the water when the rooms are up to temperature.
Another point one radiator must be left without a TRV to act as a bypass.
I would strongly recommend fitting a programmable stat which will efficiently control the heating 24/7.
Post by htg engineer » Fri Dec 19, 2008 2:33 pm
Yes, if you want the CORGI installation certificate. As regulations state there should be a room stat fitted on all new installations.
Htg
Steve the gas
Post by Steve the gas » Fri Dec 19, 2008 7:18 pm
As Htg,and the rad nearest the stat should not have a TRV on it also.
paulanliz
Post by paulanliz » Fri Dec 19, 2008 10:27 pm
Thank you every one for your replies, a room stat will be fitted
