Rushing water sound
Postby rja » Sun Oct 14, 2007 10:07 am
Help would be appreciated in identifying the cause of the noise made when the central heating system is at work. The noise seems to be confined to the airing cupboard and sounds like the tide 'wooshing' shingle up and down the beach!
Two heating engineers have failed to fix or even identify the cause of this noise and i am reluctant to pay out again without knowing if what I am being told is.... correct.
I have bled the rads and the vent pipe in the airing cupboard. The only thing that seems to help is turning the boiler heat setting to a level where the waters is to cool to be of practical use.
Any ideas?
Thanks in advance.
rja
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby The Heating Doctor » Mon Oct 15, 2007 7:00 am
What have you been told? What type of boiler do you have? Is the boiler/pump/hot weater cylinder in that cupboard. Is it copper or plastic pipes in there? Can you identify what each pipe is in the cupboard and what dia. each is?
The Heating Doctor
Rank: Foreman
4.7%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
