safety valve discharge
Postby uk_ducati » Mon Sep 07, 2009 4:49 pm
hi
i have been called out to fix a sime friendly format 80e combi boiler. the problem is the presure gauge is at about 4 bar and there is water comming from the presure relief valve pipe whilst cold. i have narrowed it to the dhw heat exchanger leaking into the primary circuit. the problem is that when i isolate the cold water to the boiler the pressure drops but keeps on dropping to 0 bar. i would have thought that it would stay at 3 bar when the presure relief valve closes. Is this correct of is there a fault with the presure relief valve aswell
any advice would be welcome
cheers
paul
uk_ducati
Rank: Ganger
Progress to next rank:
20%
Sponsor
Simply Build It
Postby htg engineer » Tue Sep 08, 2009 3:47 pm
With the cold water turned off is there still water coming from the PRV ? If the pressure relief valve reaches 4 bar, it'll dump enough water to take the gauge to 0.
htg
Rank: Project Manager
Postby uk_ducati » Tue Sep 08, 2009 6:34 pm
yes water still comes out of the PRV when the water is turned off. It keeps on discharging until the gauge reads 0 bar. What I am wondering is if the PRV is stuck open as I think this has been happening for a while judging by the state of the wall where the water hit it
I might just put a new one on whilst the system is drained to be sure
Am I in the right ball park with me thinking it is the DHW heat exchanger. I have checked the filling loop and that is fine
cheers
Paul
uk_ducati
Rank: Ganger
20%
Postby htg engineer » Wed Sep 09, 2009 5:58 pm
Turn off the cold water to the boiler, and run the heating, if the pressure doesn't rise to 4bar, then yes change the plate heat-ex.
And yes, I would also change the PRV.
htg
Postby uk_ducati » Wed Sep 09, 2009 7:52 pm
hi
thanks for the tip but i cant run the heating as the PRV lets water through till the gauge reads 0 bar thus stopping the boiler from firing.
i will change the heat ex and the prv and will let you know how i get on
cheers
paul
uk_ducati
Rank: Ganger
20%
Postby uk_ducati » Sat Sep 12, 2009 8:10 pm
hi
managed to do it with replacing the PRV and DHW heat exchanger.
both had rusted
cheers for the advice HTG
paul
uk_ducati
Rank: Ganger
20%
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
