Vokera boiler losing nearly all pressure daily...?
Postby pmg1173 » Tue Oct 09, 2007 12:10 pm
2 problems, furthest away radiator is always cold, it was moved slightly when we first moved in by house builder as it was in the wrong position, only one affected. Hubby has cleaned out system and adjusted the thermostat on the radiator and seems to have helped, but the boiler is losing pressure daily, have raised it to 2, later in the day it is back at nearly 0. No obvious leaks that we can see, does it need repaired urgently if under the floor or is there an alternative. Don't want to call out anyone if something we could fix ourselves.
Thanks in advance for any replies.
pmg1173
Rank: Labourer
Progress to next rank:
0%
Sponsor
Simply Build It
Postby htg engineer » Tue Oct 09, 2007 4:12 pm
Firstly you need to find the problem.
If it's losing 2bar everyday I would imagine you would notice if it was a leak.
Check pressure relief valve isn't leaking (should terminate outside)
Check if pressure rises when the combi fill is turned off and heating on (if it does it could be pressure vessel or plate heat-ex at fault)
What is the boiler make and model ?
Rank: Project Manager
Display posts from previous
Sort by
Order by
  • DIY How to Project Guides
  • Related Topics
