which cleaner is best?? see last post please
14 posts   •   Page 1 of 1
beesley121
by beesley121 » Wed Mar 25, 2009 11:18 am
Hi guys,
im i need of a condensing boiler as mine current boiler is 30+ years old and is playing up.
i live in a semi detached house with 7 standard radiators
i have heard good reports about worchester so im thinking of getting one of those but not sure what model. can you please advise
by htg engineer » Fri Mar 27, 2009 2:42 pm
Combi or system boiler
htg
beesley121
by beesley121 » Mon Mar 30, 2009 1:53 pm
combi mate
beesley121
by beesley121 » Mon Mar 30, 2009 2:37 pm
forgot to add
what do people think of the worchester 24i junior greenstar??
beesley121
by beesley121 » Thu Apr 02, 2009 2:42 am
can anyone please help m with this??
i would really appreciate a professional opinion
by htg engineer » Thu Apr 02, 2009 11:43 am
Worcesters are good boilers, it all depends on what flow rate you want for showering etc as to what model to go for. Vaillants are v.good boiler.
htg
mykylyn
new boiler
by mykylyn » Sun Apr 05, 2009 4:38 pm
1st and best option is to get your existing boiler repaired, a good heating engineer will be able to source spares. If you still want to replace a 12kw regular (condencing) best replacement. If heating engineer wants to fit a combi say bye bye to him at once, as it'll be for his benifit not yours. Combis only ok for one person dwellings.
Steve the gas
by Steve the gas » Mon Apr 06, 2009 5:51 am
Yer what??
Run that past us again please..............
by htg engineer » Mon Apr 06, 2009 12:09 pm
Rubbish every house/case is different. I have a combi and it's ideal for what we want/use.
30+ year old boiler - parts are probably obsolete, if not they'll be expensive as they will be trying to overprice the parts of these boilers to get rid of them, so you go for a newer, more efficient boiler.
The majority of people want combi's now, they're ideal for most situations unless you have more than one bathroom that will be used at the same time.
Everyone is entitled to their opinion - and in my opinion what mykylyn is saying is total garbage.
htg
beesley121
by beesley121 » Tue Apr 07, 2009 2:14 am
thanx for yer help with this guys.
can you tell me whats the best product on the market that i can add to the system to clean it before the new boiler is put on.
thanx
Mandy123
by Mandy123 » Thu Apr 09, 2009 8:54 pm
You can use Fernox, but you might need a complete new system if it is 30+ yrs old, there will be a lot of gunge built up. Your installer should be able to advise, get a few round for a chat, they all say something different. Worcester is good brand, I did a load of research and ended up with the 30Si for a 2 bedroom big flat, I should've maybe got the 30CDi, which is a bit better. Check your council/energy provider for grants too.
by htg engineer » Fri Apr 10, 2009 8:26 am
beesley121
by beesley121 » Thu Apr 16, 2009 5:25 pm
i had a look in screwfix and there seems to be 2 sentinel products that i could use to clean it out but not sure which one to get.
There is a x400 sludge remover for £13.20 and a x800 jetflo sludge remover for £21.52.
The x800 says its powerful stuff, which i think i will need consider the system is over 20 years old but it says it is ment to be used with a power flushing system which i nor the plumber have. Will it be ok if i put it in and run the pump for a few days and then drain the system??
how long should i leace it in there for for best results?? im just trying to save myself some money.
by htg engineer » Fri Apr 17, 2009 8:24 pm
Sorry for the delay in replying, I would use the X400, the X800 is designed for use with a flushing machine.
You can leave the X400 in the system but I wouldn't leave the X800 in as it is meant for flushing prolonged use may damage the system more than it'll help. You can leave the X400 in for up to 4 weeks, a few hot and cold flushes and you will be ready for the new boiler.
Also worth considering using X300 after the installation to remove the copper filings and flux from the newly soldered joints.
Then add X100 to pro-long the life of the system and re-plenish every you drain the system.
Also have a look at Magnaclean, it's basically a filter that you empty to remove deposits from the system, it also incorporates a one-way valve for dosing of the system.
X400 £13.20
X300 £13.89
X100 £12.71
Magnaclean £80.00
£120.79
It may seem expensive or OTT to some people, but prevention is better than cure. Still cheaper than a £500 powerflush though.
htg
