Tripping Halstead Ace High Combi boiler
davewuyts
by davewuyts » Sat Sep 21, 2013 10:38 am
Hi Everyone
We have a Halstead Ace High Combi boiler which has begun to misbehave. I'm thinking it needs a new PCB but wondered what any experts would suggest. The symptoms are as follows:-
1/ Boiler will trip off every morning if on timed, and also if hot water is turned on when boiler is set to "hot water only" as in summer use. When reset, the hot water will often still not fire up the boiler.
2/ When boiler put on constant it will trip once, occasionally twice, then will work normally, whole system heats well. Hot water then works normally.
3/ Occasionally boiler will not trip but nothing will happen anyway- water will run but will not fire up boiler.
Pressure in system is good, rads all heat, no air in system, when boiler fires everything works as normal and keeps working. Timer clock is working normally.
Any ideas?
Dave
davewuyts
Re: Tripping Halstead Ace High Combi boiler
by davewuyts » Tue Oct 08, 2013 4:10 pm
Anyone?
