Summary: Magnets for Builders, Plumbers and Gas Fitters
Business is, for us all, very competitive with margins being squeezed by the arrival of new and cheaper, although not necessarily better, competitors.
In order to stay one step ahead of the competition you need to:-
We can help you with all three:-
The first way to reduce unnecessary expenses is to buy a builders magnet. It is reckoned that a builder loses £50 worth of tools a year. Most magnets come with a good length of rope, in most cases 10 metres and they are designed to rescue ferrous based tools from cavities, small holes or water.
The other way to reduce your costs is get more miles out of the gallon. Products are now available on the market that will allow this. Simply fit them to the fuel line of your vehicle and they can help in reducing fuel consumption and also greenhouse gas emissions.
You are the most important asset your company has and you need to protect yourself. The job that you do is very hard on your body and a magnetic bracelet will help reduce back pain, Arthritis and Rheumatism. Any product that can reduce the time lost due to back pain or general aches and pains must be good for business and leisure.
“A Study of people with diagnosed arthritis and pain in their hips and knees found that wearing magnetic therapy bracelets reduced the amount of painkillers they needed to take, and the stronger the bracelet the greater the effect” Daily Telegraph 17/12/04.
When the marketplace gets tough and competitors start to compete on price it is worth looking at adding new products and services which you can financially benefit from. By selling a value added product and providing the service of installing it you will gain a new source of income.
A good example of this is the product supplied by Gas Miser. They are designed to reduce your customer’s natural gas consumption. Attach a Gas Miser onto the gas pipe going into a boiler and it will create a leaner and cleaner burn which means that the Gas burns at a higher temperature. This in turn allows you to reduce the temperature on the thermostat on the boiler to get the same temperature that your boiler had before and this, of course, means reduced use of gas. The Gas Misers also helps keep the boilers cleaner internally. These are supplied in several ranges - one suitable for household boilers, the bigger Gas Miser 2 which is suitable for small to large businesses and finally we have the deluxe model the Gas Miser Pro for both household and business use. This Gas Miser Pro generates a phenomenal 12.2 Tesla compared to the Gas Miser’s 0.2 Tesla and the Gas Miser2’s 0.8 Tesla. All Gas Misers are easy to install and the financial benefits to the customer are huge with up to 20% reduction in gas consumption to be made.
The Limescale Goodbye range is designed to reduce and inhibit limescale build up. The U.S Bureau of Standards in the USA reports that a .9375cm build up of limescale in the pipes will lead to a 55% increase in energy use. This means that you would be paying £130 more for your hot water on a yearly basis with this limescale build up on an average 3 bedroom house. The saving made by the Limescale Unit is separate to that which can be made with the Gas Miser. The basic Limescale Goodbye unit needs to be fitted on the mains water pipe, the water intake pipe for the boiler and the water inlet pipes on the hot and the cold water tanks to achieve the best results. The bigger Limescale Goodbye 2 is suitable for small to large businesses and finally the deluxe model the Limescale Goodbye Pro is so powerful only one unit is needed for a large house but it’s ideally suited for large business premises too. The Limescale Goodbye Pro generates a phenomenal 12.2 Tesla compared to the Limescale Goodbye 0.2 Tesla and the Limescale Goodbye 2’s 0.8 Tesla.
Adjustable Basin Wrench |
Bahco Combination Spanner Set 12Pcs |
Forge Steel Tool Belt with Holster & Pouch |
JSP Safety Dust Goggles |
Monument Tools Magnetic Telescopic Plumbers Mirror |
