WELCOME TO OUR CONSERVATORY FOUNDATIONS PROJECT
Summary: Conservatory foundations
This project will only apply to your conservatory if it is not governed by building regulations. The construction of a conservatory, for example,  which involves the conservatory becoming part of the existing building by removing external doors, or making an opening into the conservatory with no doors on, means the conservatory will be governed by building regulations. This is because it now becomes subject to insulation regulations requiring it to retain the required amount of heat.
Most Double Glazing Companies will help you with your needs and can explain requirements to you if you are going to fit one of their conservatories on a DIY base.
The building regulations will very likely stipulate, in these situations, that the foundations be taken down to 1 m or to local authority approval. The local authority approval guidelines (Building regulation requirements for foundations under table 12) are given in our foundations project.
Just because, in other cases, your conservatory construction is not governed by building regulations does not mean its ok to lay a little concrete and get on with it. For your conservatory to stay upright for any length of time it makes sense to follow the guidelines as they are there for your benefit, not the councils. The ground you lay your foundations on should be firm, not wet and spongy. Dig down to what you believe is solid ground. Cut a square peg, 50mm x 50mm and bang it into the bottom of the trench with a lump or club hammer. You should not be able to drive the peg in any more than 150mm (6inches) without difficulty. When you concrete the mix should be 6 of mixed aggregate (ballast) and 1 cement. See our mixing concrete project for help with this. The foundation trench should be wide enough to accommodate whatever thickness of wall you have in the centre, with a 100mm overhang either side.
For example;  If you have an internal skin of blockwork of 100mm, plus a 50mm cavity, plus an external skin of 100mm brickwork this is a wall thickness of 250mm. Add 100mm either side of this and the trench width should be 450mm. Again this calculation does not supersede any given with building regulation requirements.
Conservatotry Foundations
Forums
Groundwork and Foundations
Post new topic
No new posts bonding old foundations to new foundations
1 willmurph 159
rou View latest post
No new posts Foundations near existing basement and over sewer pipes
2 dutch001 177
rosebery View latest post
No new posts Foundations/footings in mixed rock/clay
0 Miradlyn 594
Miradlyn View latest post
No new posts DPC to suspended concrete ground floor
1 Shelly An 392
elwood View latest post
No new posts Footings for internal wall of extension
1 jimamberd 1578
bd3cc View latest post
No new posts FOUNDATION OF OLD STONE HOUSE
2 STEF 821
STEF View latest post
No new posts Concrete garage floor
2 Cala Sona 1556
Cala Sona View latest post
No new posts Joining to existing footings
2 TURNWISE 2110
uk's best View latest post
No new posts Excavation depth for concrete floor?
1 Urchin 1151
stoneyboy View latest post
No new posts insulation and filling in floors
0 clementsj 499
clementsj View latest post
No new posts Copper water pipe in ground?
1 jimamberd 1318
slumlandl View latest post
No new posts Wet Underfloor Heating on existing concrete slab
1 mgould 3461
tonyjacks View latest post
No new posts dpm and dpc on beam and block ground floor
0 goranknez 1263
goranknez View latest post
No new posts Sloping Drive
2 colc 1271
Perry525 View latest post
No new posts Laying block on flat (concrete foundation depth)
1 Paul-E 2633
TheDoctor View latest post
No new posts Soil Pipe
1 WHYDIY 1265
No new posts Double garage foundation query
2 karl hurr 2367
No new posts d.p.c. internal floors
1 tram44 2778
tjer52 View latest post
No new posts Manhole cover with vent - can I remove the vent?
2 pipedream 1765
pipedream View latest post
No new posts hardcore
1 jodog 2484
No new posts Concrete Mix
1 Colin2280 8472
No new posts foundation for a patio
0 russellfl 3180
russellfl View latest post
No new posts shed base
2 br2004ad 5474
br2004ad View latest post
No new posts Unknown pipe
2 fuzzyvegg 1430
No new posts 10FT Swimming pool base
1 NIKNAT 2076
No new posts Shuttering 2 sides
10 g30rge 3416
No new posts my new extension has a gas pipe underneath
0 paulb2 1666
paulb2 View latest post
No new posts Ideas on costs for a driveway?
0 mitch1000 2211
mitch1000 View latest post
No new posts foundation regs
2 stableinf 4810
stableinf View latest post
No new posts Garage renovation
1 rye_n_lou 1509
No new posts Do i need a stepped trench foundation?
0 m7ohn 2067
m7ohn View latest post
No new posts Cavity lean mix
1 Dorset 1816
No new posts Depth limit on hardcore
4 Grumpy Bo 3619
No new posts conrete mix
1 peter59ba 7000
No new posts Concrete Base for Shed/Office
3 richardra 6764
richardra View latest post
No new posts concrete floor, balast?
1 vanman 3520
No new posts Foundations for a car hard stand
2 aleck 3371
aleck View latest post
No new posts Why Hardcore under concrete bases? what effect does this hav
2 kendellst 6416
No new posts Laying Patio Slabs
2 slaphead 6909
No new posts generator foundations
0 Mikumi 1781
Mikumi View latest post
No new posts building skatepark
0 skateordi 1182
skateordi View latest post
No new posts DPC above or below concrete slab??
1 old still 4679
No new posts Best mix for concrete bases
2 supersi 12344
No new posts Gas pipe in footings
4 gillygog 4108
No new posts concrete base within existing wood shed
2 pedestal 4178
No new posts Piled foundations
6 Jimbo2008 9496
No new posts brickwork in extension will it need pillars
1 gazpad13 2950
No new posts sewer pipes going through footings
1 gazpad13 5118
No new posts Base for a wooden shed/workshop
2 mike744 5793
No new posts plumbing!
1 mckinnon1 1902
Display topics from previous:
Post new topic     -> Groundwork and Foundations
Jump to:
