Eddy
WELCOME TO OUR HARD WATER PROJECT
This project is presented by Eddy
Summary: Dealing with Hard Water.
There are a number of ways of dealing with limescale deposits caused by hard water, as experienced by over 60% of British homes. This project discusses the options, and describes fitting of an electronic descaling device. This is a simple job to tackle which will alleviate the problems of limescale build up in most homes for substantially less cost than a conventional chemical water softener.
The problem
Familiar with these problems? Furred-up kettle? Clogged shower head? Hot taps running slowly due to clogged pipes? Stubborn tidemarks around baths and sinks? White stains on taps, even though you've just cleaned them? If you suffer these, then join 60% of the British population. You've got a hard water problem.
The solutions
There are three possible solutions:
1:Chemical limescale cleaners and lots of hard scrubbing to remove baked on limescale, added to which you've got to keep on top of the problem week after week. You'd be surprised how the cost mounts up too! Also the cleaners pollute the waste water, causing yet more problems to the environment.
2: Conventional (ion exchange) water softener. The most expensive option, costing up to £1100, plus installation charges! These devices must be plumbed into your mains water supply, and consume a large quantity of salt in order to make them function, about £8 per month for a family of four people! The water generated by these systems is truly softened, but sodium from the salt replaces the calcium in your water. This means that treated water has substantially raised sodium levels. Experts advise that this water is not suitable for drinking, so an alternative source of drinking water should ideally be arranged (separate tap in kitchen). This is particularly important if you have children in the house, as they should consume even less sodium than an adult, and on no account should a baby's formula milk be made with water treated by an ion exchange water softener.
3. Electronic or magnetic water descalers. Some devices are simply powerful magnets placed around the incoming mains water pipe. A much more effective device is the electronic water descaler, an example of which is the Eddy water descaler developed by the Surrey company BHT. They have recently introduced their updated model, the ED5002P which more than doubles the output level of the previous model to combat even the most severe limescale problems. This device operates by wrapping coils of wire around the incoming water main to pass a magnetic field through the water. The effect of this is to cause the calcium in the water to stay in solution and so inhibit it from adhering to taps, baths and kettles. When developing this device, BHT sought to better the output level of all rival devices by a significant factor whilst also managing to produce a unit that is economic to buy and run. During the testing phase they found some competing devices to have output signals so low as to render them almost completely ineffective. Also unlike some inferior devices which operate with only one coil, Eddy has two, so increasing the time for which the water is exposed to the magnetic waveform. This has been a crucial factor in its success. It's made in Britain too, and comes with a 12 month money back guarantee if not completely satisfied!
Eddy Electronic Descaler
Fig.1 The Eddy Electronic Descaling Device
Eddy represents an economical and environmentally friendly way of combating the nuisance of limescale. The treated water has an unaltered chemical composition, so is as safe to drink as normal tap water. No dangerous chemicals or cleaners are washed into your waste water. The build up of limescale is radically reduced, not only on visible surfaces like taps and kettles, but also in places where limescale damage cannot be seen, such as heating elements in washing machines, and hot water tanks. In these places, excess limescale results in increased water heating costs and premature heating element failure. After fittting Eddy any small deposits of limescale that are still present, in kettles for example, should be powdery and easily cleaned away with a quick rinse or a gentle wipe. Furthermore, of great interest to readers of DIY Doctor, the device is easily installed as a DIY operation, taking the average person no more than 30 minutes to fit. Overall, electronic water descalers such as Eddy present a neat solution to a major problem for those of us in Britain (most of us) afflicted by hard water.
Quick overview of Installation
1: Locate the incoming cold water main, usually under the sink, or in the understairs cupboard. This will usually be a 15mm copper pipe with a stopcock nearby. See an example in Fig.2 below.
A typical location of an incoming water main
Fig.2 Typical location of incoming water main
2: Choose a convenient part of the pipe which is long enough to wind the two coils of wire around it (see Fig.1, illustration of typical installed device). Ideally this will be not less than 23 cms (9 inches) long. There should a space on the wall nearby (within about 8 inches) to attach the main Eddy device, within reach of the coils wound on the pipe.
3. Wind 2 coils of wire around pipe as described in Eddy installation manual (Fig.3).
Eddy electronic scale inhibitor coils
Fig.3 Coils wound onto mains water pipe
4. Attach Eddy main unit to wall within reach of coils using the supplied heavy duty self-adhesive velcro and plug in the coils (Fig4)>. Locate a mains socket within reasonable distance of the Eddy unit to enable connection of power cable via supplied mains adapter. (Use an extension lead if necessary, keeping mains socket/power adapter away from damp).
Mounting the Eddy electronic descaling device
Fig.4 Fixing Eddy to wall and plugging in
5. Switch on and say goodbye to limescale at a cost of less than 4p per week!
Current price of the Eddy electronic descaler is £129.99 available direct from manufacturer
For further information on electronic limescale prevention go to www.eddy.uk.com
email admin@eddy.uk.com or telephone BHT on 020 8287 6668
Eddy
Forums
Plumbing
Post new topic
No new posts Immersion heater cut-out
3 jack1m 89
jack1m View latest post
No new posts Pressure Loss On Combi Bolier
2 Bimbovelo 70
rosebery View latest post
No new posts RE: Mains Valve Stop Cock
2 alaska 100
htg engin View latest post
No new posts No Water From Hot Tap - Changed Washer - Still No Water!
0 slapmatt 49
slapmatt View latest post
No new posts this is a new one on me - a tap that comes on, on it's own
4 alison197 276
alison197 View latest post
No new posts Taps switching themselves on
5 alison197 276
No new posts low pressure problem Triton Zante shower
1 tosspot26 96
No new posts Burlington Bell (The 264) leaking overflow
1 theblonde 76
No new posts what shower for flat with electric only
3 freindly 140
No new posts How can you tell the in and out feeds of a rad
3 johnny mc 540
Skids View latest post
No new posts re-solder joints
3 heps 171
No new posts Picking correct boiler
1 pc6844 128
Perry525 View latest post
No new posts One Cold Radiator
7 motoloco 668
motoloco View latest post
No new posts cost of accessing a water supply in somebody else's land
5 mikerwill 280
mikerwill View latest post
No new posts Advice on connecting and fitting Toilet please
1 AndyB 208
No new posts Combi boiler problems
2 stuart_cr 267
No new posts Cracked plastic cistern
3 gstevenz 137
gstevenz View latest post
No new posts Mixer tap problem
3 theloony1 1469
No new posts New en suite
4 russellfl 454
No new posts shower pumps
3 nick41711 1129
mike1984 View latest post
No new posts Kitchen waste floor level soilpipe
2 martcrox 241
martcrox View latest post
No new posts Hot indirect cylinder vent
2 hamish72 291
hamish72 View latest post
No new posts GURGLING BASIN - SHOWER AND BATH PROJECT: HELP!!!
9 Liquid St 989
Ally D View latest post
No new posts thread sealant for BSP connections
2 sheffield 396
sheffield View latest post
No new posts leak coming from joining wall
1 123stansb 226
No new posts No hot water pressure in bathroom - but combi boiler fed
2 roadster- 412
roadster- View latest post
No new posts how to remove kitchen sink tap
0 lucky04 279
lucky04 View latest post
No new posts Kitchen Soil Pipe Connections Advice Request
2 beamer 612
No new posts Only 3 radiators working out of 7
1 philbarro 436
steve the View latest post
No new posts moving a bathroom upstairs
1 andrew mu 221
No new posts Need help replacing shower
3 richhe 489
acsimpson View latest post
No new posts Replacement part for a Caradon Siphon.
0 Sean Wals 195
Sean Wals View latest post
No new posts Air in water system???
1 Cummo 589
No new posts indirect boiler problems heatin up water
1 brett1976 509
plumbbob View latest post
No new posts TOILET FLUSH BREAKAGE/REPLACEMENT
2 seeker 640
seeker View latest post
No new posts plumbing
2 paul moor 330
paul moor View latest post
No new posts LOW PRESSURE
0 paul moor 530
No new posts UFH and Towel Rail will the thermostats for each conflict?
2 madblacke 314
madblacke View latest post
No new posts glow.worm boiler
2 kevbuck 522
kevthered View latest post
No new posts compressor
0 Newbee 260
Newbee View latest post
No new posts New Boiler Installation - HELP!!!!
3 Yorkshire 847
Steve the View latest post
No new posts Water main Insullated Ducting entering house
0 vdub 296
vdub View latest post
No new posts Stuart Turner Pump making a major racket
0 amutimer 351
amutimer View latest post
No new posts Shower pump will not turn off.
2 iwigster 500
iwigster View latest post
No new posts Toilet Cistern Filling slowly
1 daddycool 551
No new posts water main to dwellings
1 jimbo5271 334
No new posts Garage Bathroom
2 drpaul 345
drpaul View latest post
No new posts Installing chrome towel warmer
1 raypeggy 613
speedygon View latest post
No new posts Header Tank Overflow
6 Steve Rob 1270
Steve Rob View latest post
No new posts Best Place To Purchase Baxi PLatinum 40 Combi Condensing
0 Yorkshire 327
Yorkshire View latest post
Display topics from previous:
Post new topic     -> Plumbing
Jump to:
