www.heatandplumb.com
WELCOME TO OUR BASEMENT - USING AS UTILITY ROOM PROJECT
This project is presented by www.heatandplumb.com
Summary: How to add a utility room, en suite, toilet or shower, even in the basement
WELCOME TO OUR ADDING A UTILITY ROOM, EN-SUITE, TOILET OR SHOWER....EVEN IN THE BASEMENT PROJECT
Two of our most frequently asked questions are:
"I am planning another bathroom but the soil and vent pipe is on the other side of the house. How do I overcome this?"
"I would like to turn my basement into a utility room but how can I empty a washing machine or sink?"
Now, with the help of Heat and Plumb, the whole operation is as simple as pie!! Adding an extra toilet, washing machine, dishwasher and even shower are made so simple with the use of modern day macerators. (waste pumps). Take a look at how simple it is and how it is now possible to make your dream bathroom or en-suite a reality.
Here is a chart showing you different macerators and waste pumps. Its possible to get wastes now from every corner of the building. Click on the chart to get a closer look at each pump.
www.heatandplumb.com Visit Heat and Plumb
Some macerators fit neatly behind the wc itself as shown below. Click on images for more information.
B98500 - SANIFLO Small Bore Sanitary Sysyem Toilet diagram
Some units are built into the wc, and some are stored separately out of sight. Click on images for more information.
B98505 - SANICHASSE Built-inB98506 - SANIPACK Extra Slim Small Bore Sanitary System
For an extra kitchen/utility room
Sanivite in kitchen cupboard Sanivite (Ref No 1004) is specially designed to deal with the hot soapy pumped waste water from dishwasher or washing machine, making the addition of a domestic kitchen or utility room easy even when below or distant from a drain.
  • Sanivite is a powerful pump with four inlets for connection to sink or appliances.
  • Waste water is pumped through 32mm small-bore pipework, vertically up to 5 metres or horizontally up to 50 metres or a lesser combination of both.
  • The compact Sanivite is usually concealed in a kitchen unit but can also be concealed behind a demountable panel to give access if required.
Sanivite
For an extra shower
SANISHOWER Mini Shower Waste Pumping System
B98507 - SANISHOWER Mini Shower Waste Pumping System The waste pump for showers and hand wash basins Sanishower is a small, strong, purpose designed pump for discharging hot waste water from shower and washbasin to a distant drain. The product is especially useful where a shower or wash basin is to be sited in a place where gravity drainage will be difficult or impossible to run - for example in a basement or on an internal wall of a property. Sanishower can be installed next to or underneath a shower tray with access and will discharge waste water through 22mm small-bore pipework, vertically up to 4 metres or horizontally up to 50 metres or a lesser combination of both.
For even more products from Heat and Plumb, including a whole new range of pumps and macerators from....
Macerators, Macerating Toilets
Bathroom Suites Heating Boilers Disabled Bathrooms Electrical Lighting Heating Controls Gas Alarms & Smoke Alarms
Hot Water Cylinders Hot Water Cylinders Fires & Heaters Oil Tanks Pipes and Fittings Pumps and Macerators
Designer Radiators Towel Rails Whirlpool Baths Infrared Saunas Sewage Treatment Wetroom Showering
Electric Showers Solar Heating Underfloor Heating Water Conditioning Water Heaters Bathroom Taps
Also see our project on converting a basement Click here
Check our our video section on toilets and watch the film on "toilet installation" for a visual demonstration on how to install a toilet.
Forums
Bathrooms, drainage and waste plumbing
Post new topic
No new posts Dual sink drainage
2 Tryst 84
Tryst View latest post
No new posts Outside Water Stop cock in the drive filling with water
5 Lancastri 85
rosebery View latest post
No new posts Bathroom fan
0 jtimp 18
jtimp View latest post
No new posts Adding a shower to downstairs cloakroom
1 greendog 158
No new posts shower enclosure sizes
4 sidc 230
sidc View latest post
No new posts Flush the loo - boiler runs!
3 ec145 161
No new posts resurface bathtub
3 1462calvi 112
No new posts Basin mixer
1 darkhorse 139
plumbbob View latest post
No new posts Stuck bath plug hole - how to release it?
2 psonice 347
psonice View latest post
No new posts How and whether to fit tails to bath
1 GazK 200
No new posts TOILET FLUSH BREAKAGE/REPAIR
1 seeker 282
steve the View latest post
No new posts Help we have no brackets to fit our new bath!
1 jim8280 162
No new posts Cistern siphon needs replacing, can't find one to match.
1 mishk55 186
No new posts Shower with Plug
1 Arron_tra 119
No new posts Bath tap flowing slowly or stopping when fully open
1 stevehayh 174
No new posts Thermostat for Bath Shower Mixer Tap?
1 PZ 294
stoneyboy View latest post
No new posts Shower Tray Leak
1 klt 295
No new posts Osprey II 4500 Manual Power Shower in White
1 Arron_tra 152
No new posts Bath Over Flow Sizes
1 juli-juan 132
No new posts Fitting rigid risers and shower values
1 KOlder 235
No new posts replacing 4" inline centrifugal bathroom extractor fan
5 28mad10 873
chriscba View latest post
No new posts Acrylic Bath Fitting (No Frame)
1 MalH 374
warms View latest post
No new posts Laying pipe from washing machine to drain
4 rabbit 511
rabbit View latest post
No new posts Shower Silconing - 2 Questions
1 paulr 189
No new posts New Bath + Joists
3 jameskill 1120
eric99 View latest post
No new posts Need a thermostatic mixer shower with adjustable pipe centre
1 richhe 379
No new posts Shower Door Rollers
0 jkt 423
jkt View latest post
No new posts what drop do i need on long waste run ?
1 czimmerl 351
No new posts Covering recessed pipework
2 einre 400
einre View latest post
No new posts disconnecting old toilet waste pipe from soil pipe
2 nortig 800
nortig View latest post
No new posts free standing baths
1 rose 288
No new posts Hepworth Hygienic Self-Sealing Waste Valve
1 David Bro 379
No new posts Bath Traps
1 David Bro 332
No new posts Siting a new soil pipe
1 subtlebri 726
Perry525 View latest post
2 russellfl 496
No new posts guttering overlowing
4 molemam 412
subtlebri View latest post
No new posts How to remove The concrete collar from a toilet soil pipe
2 Sixfoot3 742
elwood View latest post
No new posts Big Heavy wallhung bathroom basin
3 Nonplumbe 417
No new posts Clay soil pipe & compact toilet
4 Johna7770 4836
Sixfoot3 View latest post
No new posts Water pressure loss
6 SJLoveday 563
SJLoveday View latest post
No new posts A quick dry Wetroom Floor?
0 THEMAR 520
THEMAR View latest post
No new posts Flexy tap hose
2 chriscba 337
htg engin View latest post
No new posts Concealed push button cistern
1 miss mich 529
No new posts waste pipe & vent resiting
0 hcoulson6 620
hcoulson6 View latest post
No new posts Toilet seat fixing
0 ATonk 541
ATonk View latest post
No new posts Free Standing Soaking Bath Tub
0 barnem 526
barnem View latest post
No new posts Correct fitting / finishing of a quadrant shower cubical
3 gogs 456
No new posts Surface water
2 Graham Id 471
Graham Id View latest post
2 ALJO 681
ALJO View latest post
No new posts Toilet trouble - new cistern and wall question
1 Scaryfish 720
Display topics from previous:
Post new topic     -> Bathrooms, drainage and waste plumbing
Jump to:
