This project is presented by www.heatmiser.co.uk
Summary: Central Heating
Underfloor Heating is fast becoming the new and favoured form of central heating. Reasons put forward by underfloor system manufacturers are;
Heatmiser UK
Ltd |
When underfloor heating is installed, it is commonplace to install a programmable room thermostat (like the Heatmiser PRT) in each room, allowing independent control of each room.
However, although having a thermostat in each room gives the best level of control, you should consider how you will use the system - after all, the reason for choosing underfloor heating was to make the system more efficient. You are unlikely to walk around your home programming the individual thermostats when your needs change - for example at holiday times.
Our network able thermostats are 12v poweredand have been designed to work with our UH1 central wiring box. Upto 8 zones can be controlled from 1 UH1 and the Heatmiser TouchPadprovides central control of the entire system.
See Our Network System DemonstrationTo view a demonstration on how to program your heating within your home, click the image to the right or click here. |
How about control over the internet or by SMS ?The Heatmiser Netmonitor changes the way you control your heating, hot water and other appliances in your home. Web Browser;
By SMS (Netmonitor + Required)
Quick Links
