www.loftmasters.co.uk
WELCOME TO OUR LOFT CONVERSIONS PROJECT
This project is presented by www.loftmasters.co.uk
Summary: Loft Conversions. Making a room in the attic
Loft conversions carry many regulations and permissions with them. They are each unique and very much depends upon the condition and structural ability of your existing property. The majority of lofts can be converted and can provide you with often the most attractive and largest living area in your home, it also adds to the value of your property. With Loft Masters you can be confident that your conversion is installed by a qualified and highly skilled work force, who will carry out the work quickly and efficiently with the minimum disturbance and inconvenience.
Completed conversion project
There is no doubt whatever you will need to gain building regulation approval for your conversion. There is also no little doubt, that you will need the services of an architect. For each designed load you intend to place on an existing floor, a calculation will need to be made to prove that the floor is capable of withstanding it. You will also have to comply with the fire regulations at every point in the construction of your loft conversion.
Construction of frame work
Loft Masters  will arrange all of this for you and keep you informed at every stage.
Some properties may not require planning permission, provided the loft conversion is the first extension and does not exceed 40 cubic metres on a terraced property and 50 cubic metres on others. This condition only applies when properties are not located in a Conservation Area and are not at the junction of two public highways.
All flats require planning permission.
Click on the link for examples of completed loft conversions
Once the plans have been approved by you, and signed, they will be submitted to the Local Authority for determination under the Section 63 of the Town and Country Planning Act General Development 1990. (approx 2-3 months for approval to be granted)
Once planning has been approved we will then prepare Building and Fire Regulation plans and submit to your Local Authority Building Control department for design appraisal and structural calculations to justify the proposed design to the Structural Engineers department for checking and approval. (approx 4 - 6 weeks for approval)
Upon approval, we will then serve the necessary Statutory Commencement Notice upon the Local Authority Building Control Department in accordance with the Regulation 14 of the Building Regulation 1985 (amended 1994).
Loft Masters will then obtain the following permits from your Local Authority prior to the works commencing.
a) Skips & material use and storage on the highway (Local Authority Highways Section)
b) Waste disposal containers (New Roads and Street Works Act 1991)
Roof Construction and Loft Conversion Loft Conversions book Home Conversions book
Done properly a loft conversion will increase the value of your house considerably. A future buyer's surveyor will (or should!) check on the permissions for the conversion, and its compliance with the relevant regulations. Do not take chances. Ceilings are designed only to hold what is already there and even a cold water tank has to have its own platform within the roof void. Loft conversions really are a specialist job, and the specialists do not come any better than Loft Masters
The construction, typically is in 10 stages. An example of each one is shown below. Click through to Loft Masters  for the full explanation of the process and many more photographs .....GUARANTEED
Loft Masters give a full ten-year guarantee, with an
Insurance Backed Warranty and an after sales service, which is second to none.
Scaffold erected Scaffold erected
Scaffold is erected
Access hole in roof Access hole in roof
Access hole made in roof and supporting members lifted in.
Click here for completed conversion
Internal framing erected Internal framing erected
Framing etc erected externally
Insulation placed and stairs erected into position Stairs erected into position and insulation added
Internal partitions added, walls boarded and plastered Walls boarded and plastered and internal partitions added
Internal partitions erected, boarded and plastered.
Building inspectro is invited and scaffold is removed Scaffold removed and building inspector invited to inspect work
The building Inspector is then invited for his final visit and the scaffold is struck leaving you with the extra room you need and money left to decorate it !
A completed loft conversion
Finished Conversion
skylight Stairway Completed loft conversion
Stairway and window En-suite bathroom Completed loft conversion
For more information on what is involved in a loft conversion and how this major project can be managed to ensure the desired outcome click through to www.loftmasters.co.uk for a complete rundown on the services we provided.
Forums
Conversion, refurbishment & renovation
Post new topic
No new posts drilling through floor joists
2 sheffield 132
rosebery View latest post
No new posts Dormer in attic
1 BMM 755
Jeffx View latest post
No new posts Garage to Bedroom
0 ROTHERS 418
ROTHERS View latest post
No new posts removing external render
1 georgea36 729
ashymoko View latest post
No new posts Render
1 vkjdobbin 676
No new posts Turning a double garage into a pool room
1 gooleboy 698
stoneyboy View latest post
No new posts ballpark figure for opening up kitchen and utility
2 BMM 588
BMM View latest post
No new posts LOFT CONVERSION
1 richard68 1503
No new posts Fitting upvc door frame
1 Jamminjoe 954
tim reeve View latest post
No new posts Gas/multifuel Stove hearth
0 BMM 650
No new posts Yet Another joist question
1 spytek 1202
Edpaterso View latest post
No new posts wood burner
0 Kismet56 1637
Kismet56 View latest post
No new posts single wall garage to full conversion - options for walls
0 Shelly 892
Shelly View latest post
No new posts Little flying beetles- are they woodworm
2 Mollie 1323
EHO65 View latest post
No new posts Replacing 2 lintels in a loadbearing wall with an RSJ
1 jimuthy 1390
eljaybee View latest post
No new posts connecting flue pipe to stove pipe
0 kaos 1727
kaos View latest post
No new posts Fitting window in doorway
1 Locksmith 864
No new posts Asbestos awareness -can you help???
2 Sparkydel 2109
easylife View latest post
No new posts Out building!
0 JessP 922
JessP View latest post
1 stuboy00 2823
bd3cc View latest post
No new posts upgrading of swing doors
0 aggi59 525
aggi59 View latest post
No new posts Roof truss bracing/strapping
2 col111 2726
col111 View latest post
No new posts Floor joist dimensions
2 Roy13 3336
Roy13 View latest post
No new posts cement mix
1 heps 2676
No new posts Boxing into the Chiminey
1 shellswor 1302
Captain N View latest post
No new posts doors
0 s14fna 876
s14fna View latest post
No new posts Ventilating single skin concrete block garage
1 James1234 1178
No new posts Loft space joined to neighbours
2 d7vickers 1819
No new posts Woodworm advice please
0 lilmon 1900
lilmon View latest post
No new posts Exterior Render Over Blockwork
2 pooter101 2151
pooter101 View latest post
No new posts Garage Home cinema/music room
1 cadders 2169
Philbeep View latest post
No new posts floor joist size for loft conversion (+rsj)
3 windy55 3974
No new posts Pointing slate fronted listed building
1 clarkstv5 921
welsh bri View latest post
No new posts Joists rotted in bathroom, advice please
0 happyhero 1467
happyhero View latest post
No new posts Concrete
1 maggimatc 1533
No new posts Garage Conversion
0 PduC 2294
PduC View latest post
No new posts Fire Doors & Loft Conversions - Help!
7 Alan T 3018
Michal View latest post
No new posts "A" frame joist problem
3 Martin68 2017
Dibble View latest post
No new posts Plasterboard to Joists
2 blueeyedb 1969
No new posts Flooring a Loft - Joist Query
2 nisbet_a@ 2690
nisbet_a@ View latest post
No new posts Chimney breast - trimming back
8 spinkox 2525
spinkox View latest post
No new posts Dorma window, planning question
1 Martin68 1512
No new posts Floor Joists - Office Filing Loads
1 senses 1642
No new posts Loft Conversion
2 jontee 2865
jontee View latest post
No new posts Converting Detached Garage into additional room HELP
1 James1234 2197
No new posts removing a tie bar from a loft during conversion
0 Rileyman 1722
Rileyman View latest post
No new posts rough ceiling
1 samb 1579
No new posts En-suite conversion
1 tony77 1640
No new posts size of timber floor joists
8 katiesdad 6256
katiesdad View latest post
No new posts Reversing garage conversion.
5 stu75 1719
stu75 View latest post
Display topics from previous:
Post new topic     -> Conversion, refurbishment & renovation
Jump to:
