www.cjelectrical.co.uk
WELCOME TO OUR UNDERFLOOR HEATING (ELECTRICAL) PROJECT
This project is presented by www.cjelectrical.co.uk
Summary: Underfloor Electrical Heating
Please also see our project on the New Wiring and Cable Colours .
Underfloor Heating UK (A Division of C.J.Electrical (Ipswich)Ltd.)
Unit 7 , Edison House, Edison Close, Ransomes Euro Park. Ipswich IP3 9GU
Tel: 01473 276677   Fax: 01473 276678
Underfloor heating is fast becoming the most popular form of heating. In most forms it is inexpensive to install, economical to run, there is no maintenance and above all the heat distribution is total. It is invisible in so much as there are no radiators or heaters showing. It can be installed under almost every floor type, wood, tile and laminate making it ideal for refurbishment projects. Even laid on top of an existing floor and covered with tiles the floor height is raised no more than 20mm.  You can see from the diagrams below the advantages over normal, radiator type heating, and when the ease of Diy installation is considered with the Deviheat system, it is perfect for most heating purposes, in most homes. The Deviheat system is simply a single heating cable which, acting as a kind of element, is laid all over the floor with an optimum distance between runs.
I am new to electrical underfloor heating - how does it work?
Using a Devimat system, the cable is stuck to a mat, which in turn, sticks to the floor. The cable must start and finish at the same point to allow connection to an electrical outlet and can be thermostatically controlled with a proprietary regulator.
Traditional Heating System
Traditional heating systems emit hot air which remains under the ceiling until it becomes cold, then it falls down and results in a draught
With deviheat™
deviheat™ distributes the heat evenly over the whole floor - and leaves the rest to to the laws of
What is Deviheat ?
deviheat™ electrical floor heating
deviheat™ consists of deviflex™ heating cables or devimat™ heating mats controlled by electronic devireg™ or deviheat™ thermostats.
deviheat™ provides efficient room heating, be it at home, at the office, in a work shop, sports hall or virtually anywhere that requires comfortable warmth.
deviheat™ can be installed in all types of floor whether they are new tiled floors , concrete floors or new or renovated wooden floors.
How Easy is Installation?
The area where the floor heating is to be fitted is measured. A sketch is made of the floor to determine the size of the devimat™ needed and marked to indicate where it should be placed and position of it's power supply connections. The mat must start and finish at the same place.
Measure tiled floor for devimat underfloor heating
Next, a groove is cut into the floor and wall, approx. 10mm deep and wide, for the sensor which
Is pushed through a tube, laid in the groove. The end of the tube is taped up.
Chase floor for floor sensor Install Floor Sensor
The mat is laid out as per the plan and the matting itself can be cut to get around corners and obstacles etc. Obviously the red heating cable cannot be cut and it is important that you have worked out the length of mat you require before you start to lay. If you fax a floor plan to www.cjelectrical.co.uk they will be pleased to plan your mat for you.
Lay devimat underfloor heatingCut matting on devimat underfloor heating
Tile on top of devimat underfloor heatingCover devimat underfloor heating with tile adhesive
Tile adhesive is laid over the mat (this will require a thicker bed of adhesive than normally used when tiling) and the tiles are laid as normal. A simple, effective heating method  for approximately 0.5p per square meter per hour !
This kind of heating can be applied in bathrooms, shower rooms and wet areas, conservatories and sunrooms , kitchens and utility rooms . It can be applied to tiled and stone floors and laminate and solid wood floors .
Selection of a Devi heating system depends on the type of floor you have and the area you wish to cover. Click here for help on selecting the system applicable to you.
We have listed below some frequently asked questions, if you have any which are not on the list, or you wish to order, please go to www.cjelectrical.co.uk
Question:
Why are there two different types of mat one for timber and one for concrete floors ?
Answers
Our mats have been tested to the European standard IEC335/EN60335, it is recommended that no higher than 100W/m2 should be installed on a timber floor, as safety is paramount, we adhere to this instruction. It has been found that concrete absorbs heat at a higher rate than timber, therefore we developed a mat with an output of 150W/m2 to counter-act this.
Question
I have seen some products that are just a cable or thin foil, why is the devimat® a cable on a mesh ?
Answers
During our product research, we discovered, that it was more desirable for the heating element to become an integral part of the floor rather than a foil type that separates the tile adhesive from the floor. We know that it is a better solution for the customer to have a product with pre-determined spacing for the heating element.
This removes the problem of cables being crossed or touching, which will cause failure of the heating element and can be very costly if the floor has been finished.
We have also found that without pre-determined spacing a warm-cold ripple effect can be created with a cable system that is one length to cover a variety of areas.
The devimat® is much easier and quicker to fit, there is no waiting for special glues or primers to dry, no sticking tape over lengths of cable. Simple to fit around obstacles, a much better option than foils - the mat can be cut to suit most areas.
Question
Can it be used with wooden or laminate floors as well as tiles and stone?
Answers
The devimat® is manufactured in Denmark 'the home' of wood and laminate floors, the devimat® is perfectly safe to fit under these types of floors. Please contact us for further details.
Question
How safe is it ?
Answers
DEVI have been developing and manufacturing heating cables for over 30 years.
All DEVI cables satisfy the requirements of IEC 800. The devimat® cable is double insulated with an earthed screen under the sheath and has the approval IEC 335/EN 60335.
All devimat® systems use a floor temperature sensor connected to a devireg® electronic thermostat to control floor temperature.
Question
Won't your feet get too hot ?
Answers
The devireg® thermostat can be adjusted to accurately control floor temperature to the level you find most comfortable.
Question
Isn't it expensive to run ?
Answers
The devimat® tile warming system only uses as much electricity as a standard light bulb per m². The on-off cycling effect of the floor temperature-sensing thermostat can reduce this by as much as 50%.
Question
Who can install it ?
Answers
Anyone can install it as long as they follow the straightforward instructions supplied with the heating system. However, it is advisable for a qualified electrician to connect the heating system to the electrical supply.
The cable is guaranteed for ten years if installed in accordance with the Installation Instruction booklet.
Question
What happens if the space on the floor is not a rectangle and the mat will not exactly fit ?
Answers
The devimat® can be cut across the width of the mat between the cable loops so that the mat can be bent round to provide e.g. an "L" shape. Care should be taken to avoid damaging the cable. Under no circumstances should the heating cable be cut or shortened.
Question
Will the heat affect the tile adhesive or tiles ?
Answers
DEVI warmed ceramic tiled floors will run with a surface temperature of about 22°C and the adhesive under the tiles will be a few degrees higher. This temperature will have no effect on the tiles or the tile adhesive. The majority of the leading adhesive manufacturers have confirmed this.
Question
Can electric heating on a wooden floor cause a fire ?
Answers
A devimat® system installed to DEVI instructions will be completely safe as the cables are manufactured to IEC 335/EN 60335 standard. DEVI offers a 100W/ m2 specifically for timber floors. However, a qualified electrician should make the electrical connections.
Question
Can the cable on the mat be damaged if a ceramic tile is broken ?
Answers
It is unlikely that the cable will be damaged as there will be a layer of adhesive between the tile and the devimat® which will offer mechanical protection. The devimat® will be installed with the cable facing down. This will give the screened cable, which is already tough, additional protection.
If there is any suspicion that damage may have occurred, the cable should be electrically tested.
Question
What happens if the floor floods ?
Answers
DEVI cables and cold tail terminations are waterproof. Also all devimats have an earthed screen under the outer sheath should a fault occur.
Question
What happens if the floor is drilled ?
Answers
Floors in which electric heating is installed should not be drilled. However should the cable be damaged, the earthed screen around the cable will protect the operator by causing the electrical protection device at the supply intake position to switch off the circuit.
Question
How much will it cost to buy heating under the tiles ?
Answers
The total cost for an average 3.5m² net area bathroom (this excludes areas such as under the bath and toilet), including the DEVI floor sensor and devireg® electronic thermostat, would be £252.60 inc. VAT. Installation costs are minimal, the devimat® can be laid quickly before the tiles are fixed and the cable ends can be easily connected to a local electricity supply.
Question
How long will the heating system last ?
Answers
Once the devimat® is installed in accordance with the Installation Instruction booklet, the cable should last as long as the other electrical wiring in the building.
DEVI has been manufacturing cables and thermostats for over 30 years. We have not known any cables to fail due to age.
Question
Will the system fully heat the room ?
Answers
DEVI also install heating systems under new floors which provide full heating, but the devimat® system is used to provide a warm surface to walk on and it will keep floors in areas where water can splash dry.
Question
How is it controlled ?
Answers
The system is controlled by the floor temperature sensor and wall mounted electronic devireg® thermostat. This prevents the floor from over heating. The most comfortable surface temperature will be 22°C. this is easily adjusted (and can be increased if required) by turning the dial on the thermostat.
Question
Can you install it on a wooden floor ?
Answers
The system can be installed on a wooden floor. Normally a heat resistant compound is spread on the floor and allowed to set before laying the devimat®. As intermediate wooden floors can experience some flexing, it may be necessary to brace the floor by laying 15mm plywood and screwing it down at frequent intervals to limit the flexing so that the tiled floor has a stable base.
Question
Is it guaranteed ?
Answers
All deviheat® cables are guaranteed for 10 years when installed in accordance with DEVI installation instructions (thermostats and controllers two years).
Question
Won't there be a lot of upheaval if I install deviheat® under the new tiles ?
Answers
The new devimat® is designed to be installed on top of the existing floor so that the tile adhesive and tiles can be easily applied once the devimat® is fixed in position. There is no need to excavate the floor and the devimat® will increase the finished floor height by only 3mm.
Question
Can the system be installed on an asphalt/bitumen floor construction ?
Answers
devimat® can be installed on this type of floor as long as the surface is first coated with a primer. Refer to the adhesive company for guidance on a suitable primer.
Unit 7 , Edison House, Edison Close, Ransomes Euro Park, Ipswich IP3 9GU
You might like to check our our video section on "underfloor heating" to watch a two part film on installation of underfloor heating.
Forums
Central Heating & Air conditioning & Ventilation
Post new topic
No new posts iNDIRECT BOILER
3 wrcarr 65
DEEARR2 View latest post
No new posts Coombi boiler flow stopcock
1 dpicton 11
dpicton View latest post
No new posts Replacement boiler spec
0 garypee 10
garypee View latest post
No new posts Air Coming in Via Vent Pipe
6 Exdaddy 292
rosebery View latest post
No new posts Hot water but no heating
1 bward 110
htg engin View latest post
No new posts Simple heating question
2 Pollyerri 83
Pollyerri View latest post
No new posts digital honeywell controller has just cut out/died?
0 cambridge 7
cambridge View latest post
No new posts No power to pump
2 sshaw101 64
sparx View latest post
No new posts Glow Worm 30CXI Central Heating Programmer
1 satishk 72
plumbbob View latest post
No new posts Leaking 10mm manifold
3 buzzbomb 73
acsimpson View latest post
No new posts Electric Heating or Storage Heaters?
4 MGS84 1131
spannergu View latest post
No new posts Pressure Gauge on Trianco Eurostar immersion cylinder
0 Lancastri 41
Lancastri View latest post
No new posts Combi boiler - quality/reliable manufacturers
0 PeteP 88
PeteP View latest post
No new posts Intermitant heating
0 Roy Wilso 60
Roy Wilso View latest post
No new posts Noisy central heating
4 scroogemo 256
No new posts Wood burning stove in boat
5 ericmark 410
ericmark View latest post
No new posts New Central Heating system help with working out rad output
2 zencultur 300
No new posts Roaring noise from behind my chimney
1 wolfie882 71
No new posts No pressure in rads...
1 notgnirra 129
No new posts Central heating works except for one radiator
2 ches501 390
No new posts Central Heating circulating through header tank
2 dinoprint 162
No new posts central heating boiler
3 lyndholme 463
lyndholme View latest post
2 dpicton 269
No new posts worchester bosch room stat problem
3 angelpie 169
No new posts combi boiler noise
0 Woody3371 126
Woody3371 View latest post
No new posts WOODBURNER FITTING
1 howard jo 153
No new posts Gas boiler wiring
1 weekenddi 284
fastforwa View latest post
No new posts Basic diy under floor heating
2 cyclonebr 212
Perry525 View latest post
No new posts Getting bathrooms refitted- should be thinking about boiler?
4 vincent_1 176
No new posts fusty smell from radiator
2 hercules1 158
hercules1 View latest post
No new posts hot water but no central heating
2 wilkodriv 477
No new posts Filling loop leaks and water/inhibitor everywhere...
2 jmh1 454
No new posts Air in Central Heating system
2 lee 1020
No new posts removing a radiator with flow and return valve
1 HANDYBOY 288
No new posts Radiators not heating up
7 keithm 3109
keithm View latest post
No new posts All radiators not working except for one
2 Mark J 466
Mark J View latest post
No new posts zone motorised valve fault
1 daviesian 233
No new posts room stat isue
1 daviesian 234
No new posts 14 year old boiler
1 Dr_S 310
No new posts Central Heating Pump
2 Set One 412
Set One View latest post
No new posts Changing Room Thermostat
5 JayBentle 680
No new posts FLUES AND WINDOWS
1 dcollier 214
hamish72 View latest post
No new posts boiler keeps tripping (problem solved) :-)
2 cdk7474 521
cdk7474 View latest post
No new posts Radiator needs refilling
1 luceeannj 329
No new posts Combination Boiler diverter valve
1 boilerboy 367
No new posts Column Radiator Cold all other Radiators Hot
1 kellyd197 400
herbiemay View latest post
No new posts BTU requirements
0 herbiemay 324
No new posts Hot water but cold radiators
0 Sergetov 426
Sergetov View latest post
0 luceeannj 202
luceeannj View latest post
No new posts heating a 10' x 15' ft room
0 screwhead 157
screwhead View latest post
Display topics from previous:
Post new topic     -> Central Heating & Air conditioning & Ventilation
Jump to:
