WELCOME TO OUR ARCHITECTURAL MOULDINGS PROJECT
Summary: Fitting architectural mouldings, coving and cornices
A problem with traditional plaster coving, cornices, ceiling roses and general architectural mouldings is the degree of difficulty in installing them. We receive hundreds of questions from our users, after they have read our coving project, asking if there is an easier way to do this job.
The answer is "YES"
The job can be a lot easier using lightweight polyurethane mouldings. These mouldings replicate the traditional shapes and patterns and are absolutely ideal when either trying to recreate the atmosphere in a refurbishing project, or creating a luxury feel to a new build.
Coving Raised Door Panels
Columns Coving
Wall lamps Wall Decorations
Installing coving and cornices has never been easier. The mitres are the same and, as always, we strongly recommend you buy an extra length of your material to practice on. All trades take a long while to learn, coving is no exception. It is much cheaper to practice on an extra length than it is to throw the "finished article" away!
Classical Design Room
Polyurethane mouldings have been introduced specifically to make life easier, more varied and less expensive. The cost of a plaster moulding to recreate an ornate cornice or ceiling rose is so prohibitive that, apart from heritage run homes and palaces, we were in danger of losing the patterns altogether. The image above represents just a very few of the features you can incorporate into your decorating. Even moulded skirting can be cut and fixed easily with an incredible bonus that the skirting is hollow backed to hide all the cables and wires you have clipped to the top of your old stuff.
Take an ordinary, flush interior door and turn it into a beautiful raised panel door just by sticking the panels on. Make a feature out of a well lit wall with panels and mouldings that, yes you've guessed it, just stick on. It could not be much simpler to get a classical look in the most tired of rooms.
How about coving which is lit from the back, or a ceiling rose which is simply screwed into place. Many companies make all this possible by supplying products which are easy to assemble and install, easy to maintain, easy to clean and as inexpensive as you could hope for when it comes to quality.
Domed Light
What about domed lighting in your bedroom ? It isn't hard. Porches can be created using realistic columns, window shutters can be installed for a period look and practical privacy. Niches can be created to feature loved ornaments or pictures. The way is now open for the DIY enthusiast to create room decoration far beyond wood chip wallpaper and a dado rail.
Forums
Plastering & Dry lining
Post new topic
No new posts Have you used purpose-made artex remover?
0 rabbit 24
rabbit View latest post
No new posts Drying plaster following water leak
2 lylbf 87
rosebery View latest post
No new posts TROWHAWK
3 jimfish 162
No new posts Removing old stud walls and building new
2 jimmyfive 63
No new posts 2.4m boards but 2.6m high ceilings - how do I fill the gap
2 Ginge 147
No new posts new plastered ceiling
4 whitehart 271
Dan the m View latest post
No new posts Plaster and limewash
2 dobbsie 147
dobbsie View latest post
No new posts Replacing fibreboard on walls
4 alexeix 267
alexeix View latest post
No new posts Hole in Ceiling problem
2 Dastardle 292
kbrownie View latest post
No new posts Dot n dab or plaster concrete ceiling?
1 firstinte 435
ricky68 View latest post
No new posts Metal studwork
2 Zombies 425
demoman View latest post
No new posts issues with plastering
5 suzanne h 633
No new posts Fibreboard ???
4 angela 378
No new posts bonding out a ceiling????
1 rambo77 266
No new posts Vapour barrier plasterboard to eliminate mould
1 daztc 325
No new posts float and set
4 rambo77 400
chris_on_ View latest post
No new posts Plastering
2 flatley 386
No new posts Existing Sinlge brick extension - raising floor & dry li
1 Leepick 386
No new posts Dry lining.
1 Markie 1026
No new posts plasterboard fixing plates
3 LOSSATBEA 574
No new posts Plaster Board
2 Mark0497 535
No new posts dot n dab
2 rambo77 702
No new posts What sort of board is this
3 Zombies 391
Zombies View latest post
No new posts Filling a large hole
1 Dragon 99 623
No new posts replastering or plasterboard?
3 Julia Rae 764
bd3cc View latest post
No new posts Paramount Wall
2 LeGough 417
LeGough View latest post
No new posts rendering/pebbledash
0 gfm198 601
gfm198 View latest post
No new posts Cleaning up After Plasterers
0 gigglehog 537
gigglehog View latest post
No new posts plastering mixes
0 john09 493
john09 View latest post
No new posts Decorating Plasterboard
1 Seders 494
stoneyboy View latest post
No new posts hydroscopic salts
2 chimney 572
chimney View latest post
No new posts The walls not sealed before they were painted ?
0 Pxxx 428
Pxxx View latest post
No new posts dryling abroad
0 dodger 310
dodger View latest post
No new posts Dry Lining External Walls
2 joe7 1290
joe7 View latest post
No new posts dry lining or plasterboard
1 rambo77 1191
alanthoma View latest post
No new posts skimming bonding and setting
0 rambo77 662
rambo77 View latest post
No new posts Damp Plaster
1 Deanharri 602
Perry525 View latest post
No new posts Finishing corners when using plasterboard
1 Superferg 892
neald View latest post
No new posts estimating cost for plastering
2 sheepmonk 1465
sheepmonk View latest post
No new posts how to make wonky walls straight by dry lining
2 plastermo 1034
plastermo View latest post
No new posts Lowering ceiling?
1 Geoff_Pot 498
No new posts using top coat stop beads
0 neald 423
No new posts Help! Painted vinyl silk on plastered ceiling!
8 Shushi 2465
No new posts window headers.
2 garryacov 516
teamleade View latest post
No new posts 6mm Plasterboard...
3 buntt 928
No new posts which paddle mixer?
2 chris_on_ 486
No new posts Double knot plasterers brush?
0 kdenny123 587
kdenny123 View latest post
No new posts taping joints?
2 petepingp 1193
No new posts Boards that can handle rain?
4 johnherit 636
No new posts plasterboard for ceilings
6 Builderbe 2169
Display topics from previous:
Post new topic     -> Plastering & Dry lining
Jump to:
