DIY Supply Conservatories
WELCOME TO OUR DIY CONSERVATORIES ( UPVC ) PROJECT
Summary: Whether you want to order and erect your own conservatory or simply get a builder to do it for you, find out exactly what is involved in it's construction, what you need to think about before you begin, what regulations are involved, how the base is constructed and how it is built
Building your own conservatory is not only extremely rewarding, it could save you up to 60% when compared to the full retail value of a new conservatory. A DIY Conservatory Kit from DIY Supply Conservatories is the perfect solution. Suppliers of both a “True-DIY” and “Pro-Fit” conservatory systems, they can provide DIY Upvc Conservatory Kits to suit any design.  Coupled with the widest range of colours and options available anywhere you’ll be sure to find you dream conservatory at the right price.
See table for an explanation of the differences between a DIY and Pro-fit conservatory
CONSERVATORY TYPE TRUE DIY CONSERVATORY PRO-FIT SELF-BUILD CONSERVATORY
Frames Styles Single Frame Modular
Large multi-lite frames up to 3m
Frame Glazing Fully Pre-glazed Unglazed. Loose glass to be fitted
Installation Instructions Comprehensive with Install DVD Instructions. Not comprehensive
Frame Connectors 18mm Aluminium, adjustable 3mm PVC or 8mm Aluminium
  No Screws, Konnect technology Non adjustable, screw together
Experience to assemble None required, just basic DIY skills Yes, some previous experience beneficial
Other benefits All parts separately labelled and bagged Available in more colours
  Faster time to install for DIY'er Wider choice of roof systems
Follow our 5 simple steps to your dream conservatory
STEP 1 :- Conservatory Design
The first thing to think about is the design you want. There are many different designs of conservatories available. Here are the most popular.
Edwardian Style Conservatory
Victorian Style Conservatory
Lean-to Style Conservatory
Gable Style Conservatory
EDWARDIAN
VICTORIAN
LEAN TO
GABLE
Click here to view a wider range of designs or to go straight to Online Quote
It is important to be aware of the Planning restrictions that currently determine the size of your new conservatory. Conservatories are considered Permitted Development, and do not require a full
Planning Permission application, subject to certain limits and restrictions. The main points are as follows
STEP 2 :- Conservatory Specification
The specification you choose for your new DIY Conservatory largely depends on what you wish to use the conservatory for. Will it be a dining room, study, playroom, breakfast room, sunroom, lounge area, or just somewhere to relax? No matter what the use is going to be you should insist on your new DIY Conservatory having a minimum specification of:
  • 70mm Internally Beaded Frames - Some companies still supply 60mm & 65mm externally beaded frames. These are not as thermally efficient as the 70mm frames and if the glazing beads being on the outside are also less secure.
  • 28mm Low E (Heat Reflecting) Frame Glazing - This is essential if you don’t want to spend more than you have to heating your conservatory during the cooler months of the year. The special coating reflects heat back into the conservatory rather than it escaping through the glass. This type of glass is 2 x more thermally efficient than standard glass. The most popular brand-names of Low E glass are Pilkington K, SGG Planitherm and AGC Planibel.
  • 25/35mm Polycarbonate - Polycarbonate is a very popular roof glazing material because it is cost effective and has very good thermal insulation values. Some companies still supply 16mm polycarbonate which is now out dated and you should stay clear of this.
  • High Performance Roof Glazing - Glass roofs are becoming more popular due to the advancements in technology. They can now out-perform polycarbonate insulation values and also reflect up to 78% of solar energy depending on the performance of each glazing type. The best products also have a self-cleaning coating for minimal maintenance. The most popular brands-names of High Performance roof glass are SGG Climaplus, Pilkington Activ and Celsius.
  • Fixing Pack & Instructions - As a part of the DIY Conservatory Kit you should be supplied with all the parts you need to complete your conservatory installation. Some suppliers do not do this or will show it as an expensive extra after the quote has been accepted.
The instructions should allow you to follow a step by step guide to erect your new conservatory and complete it to high standard of finish. All of the above specification is supplied “as standard” by DIY Supply Conservatories. For a detailed quote visit the DIY Supply Conservatories website
STEP 3 :- Conservatory Base
There are 2 choices when it comes to your new conservatory base. You could go for the traditional concrete conservatory base or, use an ever increasingly popular choice of a pre-fabricated base system.
Concrete Base:
The traditional concrete base is a very popular solution when building a conservatory. It is the tried and tested way of building a conservatory base. This can be built with a brick dwarf wall and
Conservatory Dwarf Wall Detail Image Conservatory Solid Floor Detail Image
concrete strip foundations, or using the solid floor detail for a full height conservatory. Here is a cross section for typical dwarf wall and full height conservatory bases.
Advantage & Disadvantages of building a traditional concrete base are:-
Advantages: - Easy to find a builder. Use same bricks or stone as original house Can be constructed to give excellent insulation values
Disadvantages: - Quality of workmanship and costs vary. Lots of site disturbance, e.g. skip, ruined grass, concrete lorry. Different interpretations of a good base due to no governance. Not achievable for average DIY’er
Pre-fabricated Base System:
Pre Fabricated Conservatory BaseA pre-fabricated base and wall system is becoming ever more popular, as it is the perfect complement to a DIY Conservatory. It allows the customer to complete the whole installation from start to finish without the need for a builder. They are also known as ‘steel bases’, due to the main structure being made from galvanised steel. The pre-fabricated walls are steel frames with ‘brick tiles’ bonded to the face to give the desired finish.
Advantages: - Quick and easy to erect
Supplied as a kit
Minimal site disturbance
 Ideal for sites with restricted access
Service channels built into walls
Disadvantages: - Standard ranges of brick tiles available
Cannot achieve as high insulation values as a well insulated concrete base
DIY Conservatory Instructions Cover DIY Conservatory Instructions Step 2 DIY Conservatory Instructions Step 3 DIY Conservatory Instructions Step 4
STEP 4 :- Conservatory Installation
A Do It Yourself installation provides the biggest cost saving for those who are happy to build their own conservatory.  Your DIY Conservatory Kit will contain all you need to erect your conservatory entirely yourself.  Here is an example of the step by step instruction guide from DIY Supply Conservatories.
DIY Conservatory Build Base Completed and Dwarf Wall Built DIY Conservatory Build Window Frame Added DIY Conservatory Build Completed Job
BASE DONE FRAMES UP FINISHED!
Alternatively you could choose to buy the conservatory direct from DIY Supply Conservatories and get a builder in to construct the base and install the conservatory for you.  The third option is to have your new conservatory installed onto a traditional or steel base by a professional installer using our recommended fitter service.
DIY Conservatory 3D Cad Layout PlanWhichever route you choose you will save a considerable amount of money when compared to normal retail installed prices. You will also have the satisfaction of increasing your permanent living space whilst almost certainly increasing your property’s value.
STEP 5 :- Get a Quote
For your free no obligation quotation, please fill in the Quote form below brought to you by DIY Supply Conservatories Ltd. You’re easy to understand quotation comes with Free 3D CAD drawings!
DIY Conservatory Example DIY Conservatory Example Image 2 DIY Conservatory Example Completed Job
You can also take advantage of our ‘Try before you Buy’ service. Again this is a completely free service offered to all DIY Supply Conservatories customers.
Get a quote for your DIY conservatory
