This project is presented by www.neweysonline.co.uk - Quick Click: JOB DONE!
Summary: How to fit electrical socket boxes and switch boxes into plasterboard walls
Fitting and fixing socket boxes into plasterboard is a really simple operation. Proprietary plasterboard, or Dry wall, socket boxes are available (They can be bought in the tool store below or by clicking through to Neweys Online) which simply clip into place when the hole is cut for them. Dry wall socket boxes are a joy to work with and as you tighten the face plate onto the socket, or patress, box the box grips the plasterboard tighter. The same method is used for switch boxes as socket boxes.
When you are ready for plastering onto your stud, or plasterboard wall it should look like this. The electrical cables are in place (This is called electrical first fixing) and the plaster is ready to be laid on. You can fit the socket and switch boxes now if you like, then remove them again for plastering, but it is usual to wait until the wall is plastered before they are fitted as shown on the right.
Once the wall is plastered you can follow the simple steps below.
Go to our video section on "cutting plasterboard" to watch a three part film on how to cut plasterboard correctly.
